1998 s70 t5 Heater core
cjbmustang
Re: 1998 s70 t5 Heater core
Post by cjbmustang »
Would it be pointless to take this one out and run it through the dishwasher? Its been in the car for a few years...
Thank you
Chris
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Depends on how tired you are of the smell. You can also find a odor remover and run it in the car to make things smell better.
cjbmustang
I doused it with some clorox cleaner before i put it back in. i guess i will try the dishwasher trick. hopefully my dishwasher won't smell like coolant afterwards!
Has thanked: 1500 times
Been thanked: 3812 times
You need lots of soapy water to get the oil off. Removing oil with water needs surfactant.. (Soap)
volvofl
Year and Model: 1998 S70 T5
Post by volvofl »
Take it to an independent shop that has a hot water parts washer. We have one in our shop (made by Hotsy Pressure Washer) and they work great, and don't mess up your wife's dish washer.
Ben850
Been thanked: 7 times
Post by Ben850 »
I also installed the Swedish Car Parts unit over the weekend, along with the tubes and the firewall junction which I broke removing the old hoses.
That plastic is extremely brittle, (firewall junction) You also need to have nimble fingers to maneuver the piece out, and back in around the gas pedal and cable (850) and behind the A/C evaporator.
It stinks a little, but not unbearable. I was under a time constraint and didn't wash it at all.
New stuff.
New stuff.
Brown but no leaks. Production tag- 4/17/1995 I believe.
You can see the crack in the sun lit area.
Not brown.
Not brown.
Done.
Done.
What option is this taped off connector for?
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
dosbricks
Post by dosbricks »
Ben,
I also ordered the junction w/ associated o-rings and clips but not the aluminum tubes. Did you find it advantageous or necessary to have the new tubes?
I take it this was on your '93 sedan. Was the original core leaking yet?
dos
Ben850
Post by Ben850 »
dosbricks wrote:Ben,
dos
This was for the Turbo Wagon actually.
I ordered the tubes for an extra $30. to ensure there would be no 20 year old parts left in the plumbing equation, aside from the steel tube at the engine block. "Once Bitten".
The old tubes appear to be fine and I would not have hesitated in reusing them with new O-rings.
I have some parts for the '93 Sedan, I am fairly sure the thermostat is failed in the open position as I did not get a substantial amount of heat last winter.
Of course it was 20 below zero most of the time.
Side note.
Dos, I found the Jack and the space saver spare with the ring in my storage unit. Glad you found yours first because it was buried.
dosbricks
Post by dosbricks »
Thanks, Ben. I'm also doing all hoses as PM--I already put so many new parts on the S70 that now I don't want to lose it :wink:
