1997 Volvo 850 R smoke/steam out of oil filler cap?
a '97 volvo 850 R with 185,000 miles,synthetic oil is used in it but i havent changed the oil yet. when i opened the oil filler cap today just after i drove it, smoke or steam came out of it. i checked the dipstick and there was white sort of gunky stuff on it. what is that? would an oil change fix that?
NEWS
Get it!
Saving more by one single click!
Porsche Piwis II promotion code is now right here waiting for you!
Get it!
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
How long has it been since your last oil change? The gunk on the dipstick could be just thick oil buildup but it could also be coolant seeping into the oil system from a bad head gasket, this is more likely though if the residue is milky looking. A small amount of smoke is normal especially after the engine is shut down hot but too much could signal problems with the PCV. There are some excellent threads on how to repair that but a definitive test is the rubber glove over the oil filler cap on a hot engine, if it inflates its time to replace the PCV. Post back with results.obdshawn wrote:synthetic oil is used in it but i havent changed the oil yet.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
- instarx
- Year and Model: XC70 T6 2011
Unfortunately these could both be signs of a blown head gasket where coolant is getting into the oil. But there may be other reasons, too. Some vapor from the oil cap is normal if the engine is hot, and white gunk on the dipstick can be from not driving it much, or for very short distances. Water condenses and collects in the oil if the engine is not occasionally driven far enough to get the oil hot enough to drive out the water.obdshawn wrote:a '97 volvo 850 R with 185,000 miles,synthetic oil is used in it but i havent changed the oil yet. when i opened the oil filler cap today just after i drove it, smoke or steam came out of it. i checked the dipstick and there was white sort of gunky stuff on it. what is that? would an oil change fix that?
What does the coolant level look like? if it's low that would be another indicator of a blown head gasket. What was the oil level like? If it's high (overfilled) that could indicate coolant in the oil pan. Any other symptoms, like overheating? White smoke (steam) coming from the exhaust?
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
- 3757 Views
Last post by precopster
- 1525 Views
Last post by Sommerfeldt
- 754 Views
Last post by tryingbe
- 9 Replies
- 3895 Views
Last post by E Showell
- 9 Replies
- 1417 Views
Last post by bmdubya1198
