98 S70 headlamp washers
On my '98 S70 the headlamp wipers work, but not the washers. Do the washers run off of the same pump that feeds the windshield, or is it a separate pump? How do I locate the pump(s) on this car? The Chilton manual is no help. Thank you.
- Has thanked: 2199 times
I'm trying to remember as it has been a long time since I fixed the headlight washer system. If I recall correctly (and that is a stretch!) they use the same pump for the headlights and windshield. The pump is fitted in front of the reservoir on the RH side of the engine bay near the front. You can see it more easily if you carefully pull the bottle filler neck forward and out of the upper clip. There are 2 small pipes and one of them runs to the front of the car. There are some connectors with one way valves in them, and they are prone to the diaghrams in them failing, or the nozzles blocking. The jet nozzles are also prone to blockages too. Start from the pump end, follow the pipe to the first connection, separate it and see if water pumps from there and work your way to the jets. I found there was a 'T' connector under the RH headlight that was generally the failure point. Parts are stupid expensive for what they are, so worth checking in breakers yards.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Have someone activate them and check for a massive leak somewhere. I usually use a metal bread tie stripped of it's plastic to jam down washer nozzles to clear them if plugged.
- 2171 Views
Last post by smacknab
- 816 Views
Last post by packetfire
- 955 Views
Last post by durk80
- 1055 Views
Last post by jimmy57
- 1717 Views
Last post by oragex
