1995 850 won't start, doesn't crank, no click
- Has thanked: 311 times
- Been thanked: 817 times
But definitely worth mentioning, good post.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Bad battery symptoms. How old is the battery? If the battery has a few bad cells, the good cells can give off a 12+ volt reading, but not enough good cells will cause the dead start issue. Take the battery to have it tested.
Not the battery, or at least not just the battery. Cleaned the battery clamps & swapped in a known good battery from my 240. No change. Haven't been able to test the ignition switch yet.
How does one go about testing the ground? Is there only one ground point, or are there multiple grounds that have to be checked?
Edit: Missed Ozark Lee's post, so I haven't checked that yet either... Will do.
- Been thanked: 4063 times
Multiple grounds and they are a known fail point on older cars. Scour the web for a wiring diagram and track down the grounds, clean, rebolt
- 1045 Views
- 1320 Views
- 17 Replies
- 6248 Views
- 12 Replies
- 19564 Views
Last post by wizechatmgr
- 811 Views
Last post by coflynn
