1998 volvov70 p0455 code
tom4342
Year and Model: 1998 v70 awd
Post by tom4342 »
Large evaporative leak, Ive been battling this leak forever started as a small now large i found a spilt hose on the purge tank in the fender well and replaced all of those lines and just about every small vacuum line i could lay my hand on,replaced the gas cap,purge valve,air injection pump switch,smog pump,air pump control valve,check valve etc car runs great just sick of the check engine light popping up after a hundred miles or so,suggestions? :evil:
Tom Hood
Has thanked: 2199 times
Been thanked: 1852 times
Not sure of this, but I recall there are vacuum pipes at the rear of the car at the fuel tank. Seen pipes split there and can be hard to see.
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
I'm chasing the same one. The only place I haven't gotten into is the top of the tank at the rear of the car. Access from the top coming through the rear behind the back seat area.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
It sounds like you've checked most of the usual suspects. I don't know if the '98 has the roll-over valve, but on my '97 a damaged rubber connector hose at the roll over valve was the culprit for the 0455 code. On the '97 the roll-over valve is located near the fuel filter at the RR corner.
Has thanked: 311 times
Been thanked: 817 times
My 98 has a rollover valve, definitely check the hoses back there.
tom4342
Post by tom4342 »
yep soon as it stops raining
Tom Hood
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Sounds like you covered all the main culprits, I would make a smoke tester or get it tested at a shop.
I have the same problem, but I'm not sure I fixed it, the code takes very long to appear on my car.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
After the J hose, the second most common cause of p0455 is probably the hoses at the rollover valve. It's not a fringe suggestion, I would say he definitely hasn't covered the main culprits ... not yet!
tom4342
Post by tom4342 »
this is what i found isnt there two hoses on this? if so i have no idea where the other is or where it goes.I put the hose and nut on today.
Tom Hood
tom4342
Post by tom4342 »
found the hose on the back side coming off the valve didn't feel an issues which doesn't mean there isn't, the filter looks like fun to replace, well will just keep looking.
Tom Hood
