Hello All:
My 2000 V70 N/A has thrown a P0130 code the last three times I have driven it. This code appears to correspond to a missing signal from the front (pre-cat) fuel to air ratio sensor ('99-00 use Denso, not Bosch sensors).
I have two questions:
1) has anyone else experienced this trouble code when the sensor wasn't actually at fault? These are expensive sensors, so I'd prefer to be sure it's bad.
2) Is the Denso 234-9020 Fuel To Air Ratio Sensor the correct replacement part number for the upstream pre -cat sensor? I have seen some conflicting part numbers.
Thanks!
Thanks!
2000 V70 N/A P0130
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- Year and Model: Lots
- Been thanked: 128 times
Denso made the factory delivered O2 sensors but Bosch also produce an equivalent sensor (I fitted one in my 2000 V70 na)
The 234-9020 is the correct Denso number. I have one in here. If you want it PM me.
Herb Goltz
PM sent-- thanks!
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- 21 Replies
- 18215 Views
Last post by SOURDOUGHJIM
- 1618 Views
Last post by foggydogg
- 973 Views
Last post by precopster
- 536 Views
Last post by Billy031
- 1229 Views
Last post by NSFWaldo
