2011 S40 - does it have a radio code?
RaulGuichard
Year and Model: S40 2011
Post by RaulGuichard »
Greetings,
Just bought a used 2011 S40 T5. It had some trouble with the boost sensor (code P0236) but have already replaced it. However I'm getting really poor MPG (12.5) and it isn't performing as I expected, so I'm about to do an ECU reset, just worried about the radio entering into anti-theft mode since I don't have it's code to unlock it. Does anybody know if the radio would enter in anti-theft mode even if I reconnect the cables with the key in position II or if I do it like that I shouldn't worry about locking the radio?
Thanks in advance
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Radio has no code.
Don't get your hopes up. Too much is promised for this.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Raul, I split and moved your question about fuel economy here: 2011 S40 T5 - really poor MPG
Reason: Clarified
Also -> Amazon link
RaulGuichard
jimmy57 wrote:Radio has no code.
Thanks, my hopes are not that high, but I think it may be worth giving it a shot. Just to get things clear, when you say that radio has no code, it means that it will not get locked (as if it uses another mechanism, only works on the same car) or that it will get locked but there is another way to unlock it?
Ben850
Been thanked: 7 times
Post by Ben850 »
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
jimmy57
Post by jimmy57 »
That car doesn't have a "radio" . It has a few components working on a fibre optic network to give you radio, CD, and Nav (if equipped). There is no electronic lock as there is no one thing to steal that needs protection.
The S40/V40 at the top of the thread is the Dutch built model that still uses an all in one double DIN sized, slide into the dash head unit. Those have codes as they were easy to steal units.
Ben850
Post by Ben850 »
jimmy57 wrote:That car doesn't have a "radio" . It has a few components working on a fibre optic network to give you radio, CD, and Nav (if equipped). There is no electronic lock as there is no one thing to steal that needs protection.
RaulGuichard
Thanks, just did the procedure, no problem with the "radio". I think there is no feedback that the ECU actually has been reset but the clock did so I guess it might had.
