2004 XC90 T6 Sluggish Acceleration w Check engine light on
rpfitton
Year and Model: 2004 XC90 T6
Post by rpfitton »
The car runs fine except for sluggish acceleration. Check engine light is on but I couldn't pull any codes from it. Any suggestions as to where to start. One friend told me possible O2 sensors. 99K miles original owner.Thanks.Russ
Stravlr
Post by Stravlr »
go to AutoZone or your favorite FLAPS and have the codes read. Without them it can be so many things. That said - what is different from before the no check engine light until now?
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Did the acceleration become sluggish gradually, or just one day no get up and go? An O2 sensor usually fades out, if your boost controller fails, or a hose ruptures, it will be more right now. Check all hoses and connections that you can, and maybe pop the hood and listen while someone revs it, maybe it will be obvious. Codes is the next (or other first) step.
Current Volvos:
