1996 850 Interior cabin blower motor runs after car shut off
T64me
Year and Model: 04V70R/05S60R/07S60R
Has thanked: 6 times
Post by T64me »
I have a 96 Volvo 850 Turbo with approximately 170,000 miles on it. Sometimes when I turn off the car the interior cabin blower motor continues to run. My guess is it is a bad blower motor relay - part number 9494787. Any constructive input would be appreciated.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
My guess would be a bad ECC.
T64me
Post by T64me »
Seems coincidental that I removed the radio recently and now the ECC may be bad? Is it possible that I just bumped a connection and caused a problem that way?
Has thanked: 311 times
Been thanked: 817 times
It's not likely the ECC, as the ECC does not get power when the key is off. That doesn't make the problem any easier to find but is something to consider ...
Check for a short in the wiring behind the radio, good call.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
If it shuts down after a few minutes it is due to a modification that Volvo came up with to keep the evaporator core from rotting out as quickly. They put a time delay on the blower to try to get rid of the condensation after the car is shut off.
If it keeps running and won't turn off at all then chances are you have a shorted out power stage (blower resistor).
T64me
Post by T64me »
The blower motor does not stop after a few minutes. If I pull fuse number 5 it stops - even when I reinstall this fuse right away. Does that sound like a bad blower resistor? If so, I will replace it as soon as I can get one.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The "Afterblow" function as Volvo call ot is factory fitted on the P2 series only. It can be removed by the dealer with a software upgrade.
T64me
Post by T64me »
I don't think this is an "afterblow" software related issue. The car did not do this when I first purchased it. Now it does so I am thinking it must be a resistor, relay or something else.
rspi
Post by rspi »
It's still broke?
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
The ECC unit comes with temperature sensor.
Is that a suspect, pn 6849017?
