'99 V70. No start condition MVSOLVED. New batt cables
draser
Year and Model: 2005 S60 2.5T
Re: '99 V70. No start condition
Post by draser »
Misha, do you care to explain how do cables go bad, I'm curious?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Because of their age,they get burnt inside the insulation and become pretty hard and loose their flexibility from high amp current."Burnt" cable inside is making a high resistance and that resistance is killing normal and needed current flow.
On a bad cable which looks perfectly normal you can get 1-2v of voltage drop.Since the system use 12v,you can imagine what damage and problems bad cables can produce.They are that thick for a reason.If you would install thinner cable it would melt for a short time.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
draser
Post by draser »
A cable is just a piece of copper pulled in strands and twisted together inside the insulating jacket. Phisically, copper does not change it's properties due to electrical current flow. Just look at hight voltage lines, they run forever without replacing any wires. What actually gets hard and brittle is the jacket, which is just physical decay of the polyethylene material. The voltage drop is caused by the crimped end lugs getting oxydized, copper strands getting green and lugs getting loose. It's just contact resistance increase. That's the weak point. Unless cable is cut or nicked, which reduces it's cross sectional area, it's as good as new.
misha
Post by misha »
When you perform a voltage drop test on new and on bad cable....you will see that you are very wrong.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Afew years ago my 1993 960s cables had the white and green powdery deposits close to the battery so I sliced the insulation with a blade to around 8 inches before the terminal then poured hot water to clear the white powder. Then I applied vaseline and tape wrapped them to avoid moisture entry. New terminals were fitted and starting problems disappeared. I had slow cranking with a fully charged battery before the repair.
I don't like spending money 8-)
Has thanked: 292 times
Been thanked: 765 times
Voltage drop, we need voltage drop numbers, Mike!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
OK -- So here's the latest. Another near no start yesterday and a no start today. I am awaiting the arrival of new battery cables from www.genuinedealz.com in Georgia. It is going to be a few more days before I get them.
I went to put my Schumacher 2/10/50 charger on the battery and now, while set at 2 amps I hear a popping sound from the charger and the needle swings all the way across the face of the charge gauge when the popping sound occurs. I immediately disconnected the charger. Is this tripping a breaker within the charger? What could be causing this? Until I know, I am reluctant to use the charger for a protracted -- say 24 or 36 hour -- charge on the 2 amp. setting.
The charger isn't exactly new and it could have given up the ghost. Any thoughts?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
misha
Post by misha »
Could be a shorted cell inside a battery.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
E Showell
Post by E Showell »
Apparently, it is normal charger behavior for a deeply discharged battery.
'95 855 auto (sold)
misha
Post by misha »
If it's that discharged battery after a day,you have a MAJOR parasitic drain or a shorted cell.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
