2003 S60 what is needed to reset ATF fluid count
Delirious
Year and Model: '00 S70 '03 S60
Has thanked: 3 times
Post by Delirious »
In preparation to change ATF I need expert advice as what is needed for the software part of the job. I already have an Autel scanner and a Vida 2014a software (downloaded). To get Vida to work with my laptop I was going to get a OBD2 to USB cable,
1
1
VAG KKL.JPG (50.07 KiB) Viewed 1818 times
but they also have other fancy gadgets (2nd picture).
2
2
Volvo Dice.JPG (30.57 KiB) Viewed 1818 times
Can you explain the difference?
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The blue item won't work with Vida software.
The Dice is designed to work in unison with the Vida software and explore all the menus contained in the interface.
I've never heard or read about any other scan tool working with Vida.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
First one is a funny whistle (from your Volvo point of view :), the other one is what you want. If you buy a Chinese clone, buy from a reputable seller: lots of clones are malfunctioning garbage.
osman
Year and Model: 2002 c70 hardtop
Post by osman »
The Vag-Com cable works seamlessly with VOl-FCR and is an indispensable tool for 96-98 Volvos.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
Delirious
Post by Delirious »
O.K. so before I go and invest in another scan tool, VIDA dice is the only way to reset the ATF counter?
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
osman wrote:The Vag-Com cable works seamlessly with VOl-FCR and is an indispensable tool for 96-98 Volvos.
I can see Vag-Com, but what is VOl-FCR, osman?
Our '97 850 feels left out now that the 2001 V70XC is often hooked up to VIDA-DiCE.
Dice with Vida is the only way to reset the fluid counter. There is another tool which is just as expensive as a Dice that works with Vida however can't recall the name.
Of course Dice/Vida can also get the transmission into Adaptation which is probably more important than the fluid reset.
Delirious
Post by Delirious »
O.K. so vida dice is what will work but how about "M-VCI". It is suppose to support vida software and is also good for other cars. Anyone have or use one? Please refer to the picture attached.
$_57 (6).JPG (39.08 KiB) Viewed 1773 times
$_57 (4).JPG (76.69 KiB) Viewed 1773 times
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
There are things I don't know about Volvos and this is one of them.. No one here at MVS has used that system.
