2001 s60 replace worn out T5 with 2.4T?
rohran
Year and Model: 2001 T5
Post by rohran »
I've got a T5 with 220k on it. I want to replace it with a 2.4T that I picked up that has only 25k on it. Will this work?
Vovo_merz
Year and Model: 2007 s60R
Post by Vovo_merz »
probably not, I had done this once and after the transmission would not engage, maybe I did something wrong but was told later in life that t5 and other engines have different trannys that's why it didn't work for me but was able to get the engine running fine just couldn't drive it so ended up auctioning the car
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Some Volvo dealer techs I know have done that swap and LOVED it. The only issue was the higher comp ratio 2.4T engine wants premium fuel when it run with T5 boost pressure, timing, and fuel rates.
The engine gains a bit of torque and HP over the 2.3L it replaces. Is durability and longevity affected? Probably if you drive the poop out of it all the time.
The T5 and 2.4T use the same part number transmission if it is vehicles using the same torque converter and final drive ratio so the issue with trans after engine swap was not due to the engine you used.
rohran
Post by rohran »
I'm planning to swap everything.... engine, tranny, struts, axles, rack and pinion, and spindles.... everything except the calipers. I will end up running the 2.4T engine with the T5 electronics. I always run premium, so that may not be a problem. My only concern is if possibly the engine harnesses are incompatible.
Vovo_merz
Post by Vovo_merz »
As I remember all the harnesses is the same if you are using engine with years close to yours if 2004+ then there might be few different plugs
1995 - 850 1st
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
rohran
Post by rohran »
thank you... I was hoping for that confirmation before I start the project. Years are both 2001
rohran
Post by rohran »
The new engine started in the car, so far so good.
