Volvo 850 Junkyard haul
Ben850
Been thanked: 7 times
Re: Volvo 850 Junkyard haul
Post by Ben850 »
jreed wrote:Ha ha!! Yes, I agree... When I got home and went through my boxes, I found I already had two other IAC valves harvested during a previous trip, plus the original IAC that I took off of my car a few months ago, saved in case I need a component from it.
I think I have maybe five of those at this point.
I find myself collecting things that I had needed at one point, usually for diagnostics.
The funny thing is, they are not usually the issue.
It is good to come across a good ECC unit in the '95 to '98 range. Grab 103 relays.
You never know when you may find a car that has been given up upon with low mileage, or freshly replaced parts?
I keep looking. Of course I have started hoarding this series of car.
I am happy with the '96 Turbo Wagon as the daily driver, the 93 GLT N/A as the original learning experience and stand-by driver.
So having two projects for this summer, being the Black T-5R, and the '98 V70 XC-Cross Country, I know many of the little things, as well as larger will find use.
I don't know what happened first though?
Did I start hoarding parts as a way to more cars?
Or the opposite.
There is this.
There is this.
And there is this.
And there is this.
And this T-5R Under Cover.
I have not been professionally diagnosed.
Could this indicate a problem?
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Has thanked: 1847 times
Been thanked: 1710 times
Definitely not a problem (yet) you can still see your driveway!
You have a good assortment there. If only my wife was so understanding! :lol:
Ben850
Post by Ben850 »
scot850 wrote:Definitely not a problem (yet) you can still see your driveway! :lol:
Not as much understanding as getting used to I would imagine?
Not seeing the Drive so much last week.
Much better than this today.
Ben850
Post by Ben850 »
Thank you for understanding Neil.
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
Had a bit of extra time yesterday and the weather was fine so I went to the junkyard again to see what I could see. They had 6 or 8 S70 / V70 / 850's in the yard (I lost count as I wandered up and down the aisles, 'shopping'). I stopped and shot this panorama from the roof top of the red S70 on my right. There was a silver V70 on the opposite side of the aisle.
Panorama showing two S70's
In the end I got a few items that seemed useful, including a radiator cap, some side marker lights (no need for me to get any more of these -- I have two on the car and four in a shoebox), fan relay, fuel pump relay, Evap purge valves, check valves and Tee, an ECC power stage, ECC panel knob, ECC temperature sensors, ECC solar sensor, an AC drain tube, AC control relay, speakers, windshield visor with 'home link' buttons, driver's side wiper arm from an S70 (to upgrade my old 850 version which always bends away over time), gas cap, bulbs, tailgate bump stops, and other small items.
Haul June 2015
Haul June 2015
All in all, a good day exploring.
jreed
Post by jreed »
Just got back from the junkyard, where they were having a 40% off sale for Fourth of July. Big crowds...the line to check out was about 40 minutes long.
One car, a '98 V70, had an interesting intake arrangement. A MAF was duct taped to the intake tube, bypassing the turbo and air filter housing.
MAF duct taped to intake, bypassing the turbo
Haul:
Haul
Haul
Tailpipe, altitude sensor, TCV from a '98 V70, dash grill, brake caliper slide pins, caliper pin caps, caliper spring, EVAP purge valve and T fitting, gas tank cap, jack, fan relay, intake hose clamp, spare change under the seats and on the ground, ECC knobs, wheel guide pins, spare tire straps, Volvo 850 GLT trim, fuses and bulbs, trim and rubber bumper, front turn signal spring.
