1999 V70 Front Suspension noise
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
Just another thought: could one or more failed engine mounts cause clunking sounds like described? Should be easy to check the mounts including the transmission mount.
paredown
- Year and Model: 1999 V70
- Been thanked: 2 times
Endlinks are what Ozark Lee also recommended checking in the link I included above. Sounds like a good place to start!IG-88A wrote:I did a suspension refresh on my wagon last year, sans shocks and struts. All was fine for a day or two. Then I started hearing a clunk when going over uneven pavement. Turns out that one of the swaybar endlinks wasn't fully seated. I was able to tighten it down to where I thought it should have been good, but it wasn't because the bolt wasn't in as far as it would go. Sometimes those things can be a pain to get flush again. Just a thought.
If they need tightening. do I need to unload the suspension with a jack or something?
1999 na 2.4l V70 beater--donated to Habitat in running condition
JeffHicks
- Year and Model: 1989 240 Wagon,
I've replaced a LOT of sway-bar end links over the years - some on Volvos, and others on just about every other kind of FWD car.IG-88A wrote:I did a suspension refresh on my wagon last year, sans shocks and struts. All was fine for a day or two. Then I started hearing a clunk when going over uneven pavement. Turns out that one of the swaybar endlinks wasn't fully seated. I was able to tighten it down to where I thought it should have been good, but it wasn't because the bolt wasn't in as far as it would go. Sometimes those things can be a pain to get flush again. Just a thought.
Holy cow can worn ones make a LOT of noise!
It's tough to determine if they're worn when the tires are on the ground, but with both wheels raised it's pretty easy.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Jeff -- Enlighten us. What are the telltale signs of sway-bar end links with both wheels off the ground?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- dosbricks
- Been thanked: 4 times
Grab it in the middle and jerk it around. If the joints are worn you will hear clicking and feel movement.
- 992 Views
Last post by Willber
- 13 Replies
- 5702 Views
Last post by arrrxivvv
- 12 Replies
- 3356 Views
Last post by RickHaleParker
- 13 Replies
- 3209 Views
Last post by Clockboy
- 2233 Views
Last post by rubbersidedown
