1998 V70 T5 Water Pump Date Stamp
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
If it is newish, it is old stock. I don't believe they make the pulley's with the missing teeth anymore.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
rspi wrote:Volvo does NOT recommend water pump replacement unless it is leaking...
Correct.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
charleskennedy23
Year and Model: 1998 V70 T5
Post by charleskennedy23 »
Robert,
I saw your video on youtube which got me thinking about checking for the date stamp. My TB looks newish and the pump looks brand new so I went looking for the date stamp. As you can see my date stamp looks different than your AISIN pump in the video. My guess is the top number is the year and the bottom number is the month. Just checking to see if anyone can verify that assumption.
Charles Kennedy
"HAGRID": Black '98 Volvo V70 T5
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I've only changed the TB and tensioner because the car had low miles, but is it that difficult to change the WP. The bolts look accessible although tight so just unbolt, clean and replace? Or is it hard to access.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Has thanked: 311 times
Been thanked: 817 times
It is a moderate pain to clean the surface but not bad. Bolts are easy to access like you said. I always take off the serp tensioner when I am doing a water pump, so easy to do and gives you a little more space overall to work in there.
rspi
Post by rspi »
If the pump is original or has been installed by someone with a good brain, the gasket almost totally comes off with the pump. What is left almost falls off. The surface doesn't have to be spotless, the new seal/gasket swells when it gets wet. NO NEED FOR GASKET MAKER. PLEASE CUT THAT OUT!!! LOL
If you have no WRITTEN history, just replace it. Nothing like doing what I had to do, change the water pump on the side of the road. Clean doesn't = new.
You have a Volvo branded pump on a 115k engine: there is zero reason to change it out. You can go *at least* to 140k, probably to 200 k.
charleskennedy23
mecheng… I am not afraid the change the pump once I get in there. What I am really after is getting a feel for when the timing belt was done. If I can verify that the water pump is from 2012 then I'm not going to worry about the belt until I get to 140,000 miles so I can be on schedule. I can look at the car fax and determine that the car had about 102k on it in april of 2012. If the pump was done in 4/12 then the belt was certainly done then as well. It's definitely not an original belt.
thanks for all the feedback and advice. I love this forum!!!
RSPI just saw the eastern tour video. Man I am so grateful for people like you brother. You are such a blessing and I know that God is going to use you to make a big difference on this tour. I'll be praying your bride doesn't have to sleep on any couches and I am sure that even Jesus wouldn't sleep next to a dead dog, lol.
Charles Kennedy
mecheng
Post by mecheng »
I had a look at my wp: it has 81 / 07
81 on top and 07 on bottom. So I'm not sure how to read the date codes
Has thanked: 1609 times
Been thanked: 4065 times
I’ll snap pictures of two pumps I have and post - from the purchase history I can say these are dated YY MM
These are both AISIN, with the Volvo Metal casting machined off.
