Hey,
I'm having some trouble with the brake light that's located on the rear window (Sedan). It doesn't work and every time I brake, the bulb failure warning light on the dashboard illuminates. I replaced the bulb and it seemed to work then it stopped working again after I replaced another bulb that wasn't working in the tail light. Has anyone else had this issue and what can I do to check for the reason?
Thanks
1997 850 Brake Light Issue
- Year and Model: Many Volvos
- Been thanked: 76 times
The contacts at the base of the assembly get loose, they lose their springiness, and you can often get them to work again by bending the contacts on the bottom of the base down.
Tried that and it didn't seem to work. Does anyone know I can get in and check the wiring by the trunk doors? Maybe something is loose. They came on for one trip yesterday and now it's back to not working so at least I know the bulb is good!
Do a search for tailgate wiring problem - there are a couple of great threads here on how the wiring breaks over the left rear hinge, and how to fix. This is very likely your problem
here is one such thread
https://www.matthewsvolvosite.com/forums ... em#p331961
I am curious, if you found the source of your problem. I had a similar issue, and while exploring the problem, I found the ANALOGUE device which feedback open circuits to the system. As I recall, it is at the rear of the drivers side taillights. The device can be circumvented (It is a German piece of technology, which is not available). Somewhere in MVS world, there is an explanation of it, and how to alter it. All the rear light system on my 1996 lead to it.
That is the lamp monitor circuit that gives the lamp malfunction indication on the instrument cluster.jgc470 wrote:I am curious, if you found the source of your problem. I had a similar issue, and while exploring the problem, I found the ANALOGUE device which feedback open circuits to the system. As I recall, it is at the rear of the drivers side taillights. The device can be circumvented (It is a German piece of technology, which is not available). Somewhere in MVS world, there is an explanation of it, and how to alter it. All the rear light system on my 1996 lead to it.
