98 V70 T5 Manual - Low boost on ARD Green Tune
Seaway
Year and Model: 1998 V70 T5 Manual
Post by Seaway »
Fixed. Put in a third cbv, swapped out the short hose between the ote pipe and the turbo, and put in a new hose from the cbv to the manifold. Boosted like it should and held like it should.
Also replaced the faulty ABS module while I was in there.
Has thanked: 2200 times
Been thanked: 1852 times
That is great news! Must be so satisfying to get to the root of the issue with a little guidance and a lot of hard work and persistence on your part! Well done!
Seaway
Post by Seaway »
Very much so. I wish I had gotten it right the first time, but I will take it. And I can swap out a cbv in 30 minutes now, so if you need tips, just ask.
So now I have done the following : new jewel headlights, new hoses throughout, new front and rear brakes, pads, rotors and calipers, rebuilt the turbo, led lights throughout, new O2 Sensors, new transmission mount, new torque mount, new AC blower, Snabb intake pipe, pcv system, R gauge cluster, R front bumper (to match the R motor and interior) and two sets of wheels and tires.
Guess I'll keep it!
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
CBV and TBV, can anyone fill me in on what these stand for?
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
Seaway
Post by Seaway »
mika wrote:CBV and TBV, can anyone fill me in on what these stand for?
CBV = Compressor Bypass Valve (round thing on the turbo that house the spring loaded diaphragm - hose leads from it to the intake manifold)
TCV = Turbo Control Valve (also referred to as the boost control solenoid by some).
Has thanked: 311 times
Been thanked: 817 times
Seaway is not actually changing the CBV, he is removing the cover on the CBV, opening it up and switching the membrane in and out.
A torn CBV membrane is super common now to see on any of these old turbos, it is one of the first places to look when boost is limited.
TCV is mounted to the airbox.
