2009 XC90 TCS and low tire pressure?
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
Looking at a used 2009 XC90 3.2L. Haven't hooked it up to vida dice yet but they will let me.
Noted that the tire pressure warning is "on" and what appears to be "TCS" at the same time with car idleing in the photo. Any thoughts?
I would not think low tire pressure would turn off the TCS system...or is that triangle warning in the lower right something else?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
For the tire pressure thing, could be a tire with low pressure (check with a gauge), or the t press system might need a reset.
carboncow
Post by carboncow »
Thanks for your time but I think you are missing my point...of course we know what triggers a low pressure warning...but does it make sense to see the TCS come on at the same time? Is that even the TCS?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
Volvo Owner's Manuals:
http://www.volvocars.com/us/top/yourvol ... es/om.aspx
page 145 explains it, you also need to check out the warning signal in center of dash.
