'99 S70 Base -- Need Procedure for Removing Shift Lever
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Title says it all. I have the opportunity to acquire woodgrain trim for the S70, including the shift knob. Since the shift lever base on my car is damaged, I'd like to remove the entire shift lever mechanism and replace. Does anybody have a breakdown of the necessary steps? Thanks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Once you remove the console it will all be right in front of you and fairly obvious.
E Showell
Post by E Showell »
Jim -- No tricky connections between any cables and lever mechanism? Is this a ten minute swap, or am I looking at a more involved project? Thanks.
'95 855 auto (sold)
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
The shift lever base is secured with two clips in the rear of the base, then the base is pivoted forward. Base removal is a 2 minute job if that. Be aware of the light bulb assembly. Leather boot un clips.
E Showell
Post by E Showell »
But I want to bring the lever and base out as a unit. Is that still the ticket, or do I have to detach a cable from the lever somehow?
'95 855 auto (sold)
E Showell
Post by E Showell »
'95 855 auto (sold)
E Showell
Post by E Showell »
Perhaps I am making an erroneous assumption. I want to replace a cracked shift lever base and I want to swap out a plastic shift knob for a wood grained one. I assumed that was most easily done by switching out the entire lever mechanism. Am I wrong about that? I could just swap the knob and base and leave the lever alone. Thoughts?
'95 855 auto (sold)
JRL
Post by JRL »
Is this a stick or auto?
E Showell
Post by E Showell »
Auto
'95 855 auto (sold)
kahl
Post by kahl »
If this is what you want to change it simply unhooks. two clips in back then pivot it forward.
