@tryingbe
That Dual car stereo is awesome. I have a slightly different model including a CD slot in my Jeep. The SD card slot is such a great feature, I don't understand why Dual is the only company featuring it. I load up dozens of albums on a card. The display works great and it's so simple to find everything.
1999 Volvo V70R Engine stays hot for hours
tryingbe
- Year and Model: None
- Been thanked: 26 times
Yesterday, it was 115F in the shade outside here in Meas, AZ.KEWROCK wrote:You guys are really over thinking this whole thing. If the car is not running hot in 80+ weather with the A/C on. Then there is NO problem. Why invent one? The gauge sits at just past half way and never budges, plus the car is running properly. What more can you ask of it?
You would know immediately if it is running too hot, even without the "inaccurate gauge".
Just cursing the highway with a/c on gets me over 220F. Stock needle was still just at the 3 o'clock position.
There are other stereo with SD card slot, search for "head unit sd"KEWROCK wrote:@tryingbe
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
KEWROCK
- Year and Model: V70R 1999
Then one of you'r gauges is not working. I would guess It's the one that says 220. At 220 that car should be running horribly, if at all. If it is really running at 220, maybe yo need a cooler T-stat, heavier coolant mix, or an auxiliary fan. I put a 180 or 190 degree tstat in mine. It put's the needle just past half way. It doesn't get to 115 in NY but it does get close to 100.
Idk. I know what worked for me, I guess everybody has to figure their own stuff out.
My old Wrangler calls for a 210. The previous owner put a 170 in it. It ran great. When I serviced it when I got it, I put the spec tstat Jeep recommended (210), It ran horribly. Run-on, knocks, trans shifting way too late. I put the 170 back in it. Now it runs great again. The jeep forum cried foul. "It can't run like that". Tell that to my car.
1999 V70R T5 AWD Red
tryingbe
See, there are a few issues of what you said.KEWROCK wrote:Yesterday, it was 115F in the shade outside here in Meas, AZ.
1. How would you know my gauge is not working? All a stock gauge ever do is point to 3 o'clock after being warmed up.
2. How would you know what the correct operating temperature range is for a Volvo engine? All a stock gauge ever do is point to 3 o'clock after being warmed up.
3. How would you know 220F is too hot for a Volvo engine? All a stock gauge ever do is point to 3 o'clock after being warmed up.
4. How can tell you me 220F is not the correct temperature my engine should be under the condition of 115F ambient temperature with the a/c on and driving down the highway? All a stock gauge ever do is point to 3 o'clock after being warmed up.
I can go on and on, but you see the pattern? I want to know what my engine temperature at any given time. Gauge is easier to use than scanner for me to monitor my engine's temperature.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
KEWROCK
If your car is running Ok, then 3 o'clock (give or take)) is where the needle should be. If your car isn't running hot, why would the needle go up?See, there are a few issues of what you said.
4. How can tell you me 220F is not the correct temperature my engine should be under the 115F ambient temperature with the a/c on and driving down the highway? All a stock gauge ever do is point to 3 o'clock after being warmed up.
Like I said. I only know the car the kid bought, and what worked for me. I have no idea what goes on in your car, what kind of gauges you use, how their hooked up, tstat and so on.
Where the hell is Jim JRL for this thread? He knows everything.
bagman1995
- Year and Model: 1999 Volvo V70R
Hello Everyone sorry for the late reply. Everything is working fine now, the cooling fan runs just fine, usually after shutdown. Now I just have to figure out the AWD system... its done
1999 Volvo V70 R- PASSION RED
2000 Volvo S70 SE- Silver
A properly operating Volvo white block will idle and cycle between 87-105C (thats 188-221F) regardless of outside temperature. Once you move, the motion will regulate the temperature to near the thermostat temperature.
Here I am sitting at idle in 75F ambient..high reading is fan on, low reading is after fan runs.
Pix to come
Pix to come
- Year and Model: Lots
- Been thanked: 128 times
There is well documented discussion about the ambiguity of the volvo temp guage. My wife's P2 XC70 can cycle as high as 118degC (244F) when monitoring with Torque as it has the original radiator and thermostat (gotta swap them out soon) The guage sits there at the middle even as low as 85degC (188F)
Awful guage!!
Awful guage!!
Blockpartie
- Year and Model: ...
There is a very simple reason Volvo installed a self-leveling temperature gaugeprecopster wrote:Awful guage!!
If you take a look at various forums these discussions come up from time to time. While I'd like a more precise gauge I like the idea behind it as it gives me the necessary information at a glance. If it's not at 3 o'clock something is wrong.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
it's like a hundred degrees here in Texas every day this summer
busted out the scanner the other day. 185 all day, no matter what I was doing.
- 17 Replies
- 458 Views
Last post by Krons
- 19 Replies
- 1679 Views
- 48 Replies
- 10843 Views
Last post by bmdubya1198
- 694 Views
Last post by oragex
- 751 Views
Last post by qwertyjjj
