Electrical problems on 1991 240 wagon
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
leighb1
Year and Model:
Post by leighb1 »
I'm having intermittent electrical problems. Not working are Radio, Low beam headlights, parking lights, fan, power windows, wipers, seat heater light and possibly others. Working are speedometer, clock, gauges, turn signals, brake lights and Hi beam
Any ideas?
CarVolvo
Year and Model:
Post by CarVolvo »
sounds like you have issues with the fuse box.. have a look around there and see if anything is broken or disconnected.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
leighb1
Year and Model:
Post by leighb1 »
I thought about fuses but there seemed to be too many different fuses involved. And I believe that the headlights aren't fused. The mix of items which don't work all seen to be controlled by the ignition switch so I'm currently leaning that way
CarVolvo
Year and Model:
Post by CarVolvo »
i dont mean the fuses itself..but the hook up harness to it and out of it. Sometimes they get cut or loosen or ground.
Ignition key could be a culprit too.
THE FLEET!:
wojeepster
Year and Model:
Post by wojeepster »
the volvo wiring diagrams are the best that I have ever seen. I think mine cost me $27 and they are worth every penny.
https://www.volvotechinfo.com/index.cfm ... =home.main
all grounds and their locations are called out in wiring diagrams
LaRy
Year and Model:
Post by LaRy »
Hi, when you have different electrical problems at the same time it is most often a problem with the ground. Check all the ground connection points in your car. I do not know exactly where to find them in your 240. Those can easily be coroded and it is a good idea to check all connections that they are tight and clean. Maybe Volvo has used the same ground bar in your 240 as they used in 740. Then it is a long bar with something like 10 flat connectors for ground cables and the connection bar is screwed to the chassi. The bar often coroded because it is galvanized.
