Just recently the radio in my '94 850 GLT has started playing mostly static noises and the odd trace of a radio station. I have connected a continuity tester to the start of the aerial lead behind the radio and where it ends up, at one of the rear side windows. (where the aerial is printed on the glass.) There doesn't seem to be a connection. I notice that the cable starts as a normal coaxial at the radio end, but ends up in a two-thread cable at the window end.
Can somebody suggest where there might be a break?
break in aerial cable, it seems... help please!
wildatheart
- Year and Model:
1965 Volvo 122S
1970 Mercedes W113 280SL
1971 BMW 2000 Touring
1986 Ford Capri 280 Brooklands
1994 Volvo 850 20v GLT
CarVolvo
- Year and Model:
Is this a wagon?
I didn think they made 94 with arials printed on the windows like they did with later 70 series.
I always thought the arial was in the trunk behind the drivers rear fender.
The arial runs though a conduit which is just under the door when you enter and runs up the back seat to enter the trunk if that helps.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The outer wires on the co-ax cable are joined to one of the leads at the rear and the inner to the other. If you don't get a continuity reading try switching to the other wire at one end. It is rare for the co-ax to go both outside and inside unless it has been cut.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
wildatheart
- Year and Model:
billofdurham wrote:The outer wires on the co-ax cable are joined to one of the leads at the rear and the inner to the other. If you don't get a continuity reading try switching to the other wire at one end. It is rare for the co-ax to go both outside and inside unless it has been cut.
Bill.
Thank you; yes, I did think later that I should have tested the continuity for the sheath of the coax; I only tested the core.
Nevertheless, I'm pretty sure there's a break in the core somewhere. Do you know where exactly the coax becomes the two leads? I'm thinking that perhaps that's where the break might be (though I'm clutching at straws..!).
And yes, mine's a wagon; the aerial is printed on the side window.
1965 Volvo 122S
greasefingerss
- Year and Model: 850 wagon 1994
Yea my 1994 wagon has the antenna in the rear cargo space driver
Current Vehicles
1994 Volvo wagon(855) na 161,000 miles with AT
2003 Toyota Camry
1994 Jeep GC 202,000 miles
2003 Toy 4Runner
2003 Toyota Camry
2003 Toy 4Runner
wildatheart
- Year and Model:
[quote="greasefingerss"]Yea my 1994 wagon has the antenna in the rear cargo space driver
1965 Volvo 122S
- billofdurham
There should be a signal booster behind the trim panel. I think that would be where the co-ax runs to.
Also check the filament in the glass. There may be a small break in it, as happens with the filament for the heated rear window. This can be repaired.
http://www.speeding.co.uk/acatalog/Perm ... lants.html
This is a UK company but there will be similar stuff in the US shops.
Bill.
Bill.
Previously:
Previously:
wildatheart
- Year and Model:
billofdurham wrote:There should be a signal booster behind the trim panel. I think that would be where the co-ax runs to.
Bill.
Thanks for the tip & link; I did indeed check for breaks in the fillament, but 'unfortunately' this seems fine. You mention a signal booster behind trim. Is this the trim below the window?
1965 Volvo 122S
- billofdurham
It should be behind that trim just below the window. It is a rectangular box with four wires coming out of the top, 2 to the window aerial and two to the lead to the front of the car. They are sleeved so may look like only two wires coming out.
Bill.
Bill.
Previously:
Previously:
- 14 Replies
- 4272 Views
Last post by NathansC70
- 11 Replies
- 4465 Views
Last post by gusinfantino
- 966 Views
- 2315 Views
- 1390 Views
Last post by darrylrobert
