'99 S70 Outer Tie Rod Ends Rusted In Place
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
So, I've been away from the S70 for a while -- new job keeping me busy. Once I get the cockpit trim back in place and the SC-901 installed, it still needs new control arms and inner and outer tie rod ends. The outers are pretty well rusted in place. Can't budge them after lots of PB blaster and a decent amount of torch time.
Here's the question. If I am replacing the inner tie rod ends anyway, does it matter that I can't remove the outers? Can't I just remove inners and outers as a unit?
I know that I won't be about to count the turns and preserve alignment if I can't remove the outers separately, but if I'm going to have to get an alignment anyway, and can use the total length of inners and outers together for approximate alignment, can't I just remove inner and outer tie rods as a unit?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Been thanked: 4065 times
No reason to waste your time removing them from your soon to be discarded parts
It might be worth the fun to stick the tie rod end into a small container of old ATf and gas mix for two days to see if test unfree see them. Acetone is even better than gas, if you have it lying around.
E Showell
Post by E Showell »
Thanks, Steve. Will keeping the tie rod ends together pose any interesting problems in removing them as a unit? I've seen that a rubber boot needs to be cut back to facilitate removal and was wondering if keeping the outer tie rod end in place will interfere with that.
'95 855 auto (sold)
Plenty of room to pull the boot down in this pic stolen from mattymoos rebuild thread
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
You can definitely leave the outer attached to the inner if you're going to replace both.
I did it that way in the write up linked below and it worked well:
https://www.matthewsvolvosite.com/forums ... =1&t=58194
View of exposed inner and out tie rods, ready for inner tie rod end disconnection.
E Showell
Post by E Showell »
Thanks, Jason. I may chicken out and leave the inners in place (110,000 total on the car), but I'd have to be able to get the outers off to do that!
'95 855 auto (sold)
jreed
Post by jreed »
Agreed. If your inners are as good and tight as mine were a couple years ago at ~165k miles, there is no reason to change them. I replaced the inners on mine because I couldn't tell if they were good (due to my inexperience) and I didn't want to have to go back in and replace them later and have to take the time to do two wheel alignments.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
You'll need to saw the inner to get the boot off, or just get new boots
E Showell
Post by E Showell »
Already got the boots.
'95 855 auto (sold)
