I'm not interested in crawling around on my back under this car any more (130k miles, and I've had and fixed in my driveway every classic problem in the book in the 30k I have had it). Approx $1000 for a rack + someone else's labor + alignment on a car worth $1500 is tough to swallow.
There is a brief "write up" about replacing the passenger side seals on the car, but the rack appears to be different than mine:
http://volvospeed.com/vs_forum/topic/15 ... -leak-fix/
Mine looks like this: See photos. For some reason some are sideways and some are upside down - sorry
If I could get the seals out I would try the $50 seal kit from pskits.com
Problem is, my rack is apparently an SMI unit and I can't figure out how to remove the end caps. I have a face pin spanner wrench (from my angle grinder) that fits the cap, but can't turn it (tight spot?). There is a slot in the top of the rack with some kind of pin/wire in it I can see with my phone (pic).
Any tricks to removing the end cap with the rack still on the car?
Alternatively, the car is on craigslist for $1000
