2000 S70 New ETM acts up
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
So I bought a new ETM at the pick & pull. When installed the rpms rev up and down on idle. Running the etm test in VIDA shows a diff of 0.90 degrees between the sensors. (limit is like 13)
I'm not sure how to interpret this. Did the previous owner put a wrong ETM in or is it fried?
BMW 540i 2002
S70 Base 2000
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
So...you bought a used, untested ETM at the junkyard. Was the software mated to your car?
sk55
Year and Model: v70r 1999
Post by sk55 »
return it..
get a xemodex...
once they get your vin.. they will program to your car ...works great and good warranty
RussB
Post by RussB »
sk55 wrote:return it..
get a xemodex...
Although it's more money than a lot of folks are willing to spend, that is exactly what I did and very happy with the xemodex ETM. I'll never have to worry about it again 8)
kallekula
Post by kallekula »
RussB wrote:So...you bought a used, untested ETM at the junkyard. Was the software mated to your car?
The unit is from an S70 2000 NA, which is what I also have. I have bought several used ones that worked just fine.
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
get a xemodex...
A xemodex is like $500. An etm from the junk yard is like $25.
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Mike, what do you think?
BMW 540i 2002
S70 Base 2000
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Not all same model year ETMs have the same firmware numbers. The ETM test will work fine even if firmware doesn't match your car; I do the test all the time. In Diagnostics-Network highlight the ETM icon and read off your original 2 x software numbers. Make sure you press UPDATE when you start Vida whenever you swap a module. PM Doublebug with the 2 x software numbers of your original ETM and he'll sort it out for you as long as you have an internet connection. I have no problems with junkyard ETMs also except for the programming of course.
kallekula
Post by kallekula »
precopster wrote:Not all same model year ETMs have the same firmware numbers. The ETM test will work fine even if firmware doesn't match your car; I do the test all the time. In Diagnostics-Network highlight the ETM icon and read off your original 2 x software numbers. Make sure you press UPDATE when you start Vida whenever you swap a module. PM Doublebug with the 2 x software numbers of your original ETM and he'll sort it out for you as long as you have an internet connection. I have no problems with junkyard ETMs also except for the programming of course.
Thanks Mike.
Is there a way to tell if the unit is working properly, ie no internal circuit faults? Putting an etm with the incorrect software seems to set of three or four error codes?
BMW 540i 2002
S70 Base 2000
Been thanked: 4068 times
Does it pass the 8 second whine and silence test when you power it up?
