1999 V70 N/A Immobilizer
Craigd2599
- Year and Model: 2007 S40.
- Has thanked: 3 times
If you have power door locks with a key fob operator, hit "lock-unlock" five times. This clears the immobilizer
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
Shappy
- Year and Model: V70 1999
- Has thanked: 5 times
I would try that but the fobs don't seem to work. Stopped working shortly after I bought the car in February 2014. Thought maybe dead batteries but didn't need the remotes so didn't bother with new batteries. I've got the car battery neg cable unhooked while waiting for the tow truck. Will try to start it when he arrives. Just hook up the neg cable and try? or another step?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Yes...just re-connect and wait for 2-3min for board computer(info display) to go into standby mode.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Immobilisers are different in '99 models.Cars have chipped keys and as long as the key transmits correct signal the car runs.If signal is missing from key to immo or from immo to ecu...it will start but dies after a second or two.Craigd2599 wrote:If you have power door locks with a key fob operator, hit "lock-unlock" five times. This clears the immobilizer
Btw....did you checked the fuses?There are few fuses for immobiliser.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Shappy
Not sure what you mean by 'board display' and 'standby mode'? Do you mean turn the key on engine off and watch for something on the dashboard display? Or wait 3 minutes before turning on the key? Or?
No didn't check fuses. Are they labeled immobilizer? Located under hood? Will look. Immobilizer ring lights up.
Bob
Bob
- misha
Just wait around 3minutes before you turn the key to position II.
Check fuse list for immobiliser fuses,there should be three-four fuses for it.
http://new.volvocars.com/ownersdocs/199 ... 70_102.htm
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Shappy
Only 2 fuses found. Both good, but thanks for the suggestion Misha. Tow truck arrived, I hooked up the battery, waited 3 minutes and turned the key. BINGO, it's running fine. THanked the driver. I'll take it for a spin now and see what happens.
- misha
"If something doesn't hurt it means that it's pretty usefull".
When you arrive home,turn it off,wait a few minutes and then start it.If it starts and run,your problem is gone.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Shappy
Did that. Started an ran OK but ABS light came on. Scanned and got code ABS-0011 Faulty sensor Left Front. Erased code. Took it for another spin and ABS light came on again along with check engine light. Read that and it says ECM-510D. Did not erase because the last time I tried to erase the ECM codes (ECM 720A and P10181) is when I got the no start condition. Then I started it again. 2 dash lights still on. Brakes still working fine. Not sure where to go from here other than drive it with the lights on or take it to a shop with a better code reader and more experience. Want to thank all who have helped me so far.
"Experience is what you get when you don't get what you expect" Bob
- 2686 Views
Last post by aharres
- 10 Replies
- 6212 Views
Last post by GrumpyOldMan
- 559 Views
Last post by Sopyright
- 2613 Views
Last post by SeanyB
- 730 Views
Last post by xanthefin
