DIY: 1997 Volvo 850 - a supplement to Rear End Delta Link...
This topic is in the MVS Volvo Repair Database » Supplement to Delta Link Replacement
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Re: DIY: 1997 Volvo 850 - a supplement to Rear End Delta Link...
Post by xHeart »
RussB wrote:The holes in the arm are oversized to allow the trailing arm mount to be moved around until the alignment is correct
What is the purpose of black color I-beam behind the mount in your photo.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
That's the sway bar. Pic is of the passenger side looking towards the front of the car
xHeart
Post by xHeart »
RussB wrote:That's the sway bar. Pic is of the passenger side looking towards the front of the car
On our 1997 850 it looks little different.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
OK -- So, having done the delta links a few weeks back, I'd like to do the transverse arm bushings, but can't seem to remove the mounts. I'm not really interested in removing the shocks and springs. Can I unload the rear suspension with a floor jack under the spring seat while leaving the rear shocks in place? Also, the rear anti-sway bar on the driver's side really seems to be in the way whereas on the passenger side, because of where it mounts doesn't seem to be a problem.
Any suggestions?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
xHeart
Post by xHeart »
E Showell wrote:OK -- So, having done the delta links a few weeks back, I'd like to do the transverse arm bushings, but can't seem to remove the mounts. I'm not really interested in removing the shocks and springs. Can I unload the rear suspension with a floor jack under the spring seat while leaving the rear shocks in place? Also, the rear anti-sway bar on the driver's side really seems to be in the way whereas on the passenger side, because of where it mounts doesn't seem to be a problem.
Any suggestions?
It was the most fascinating project for me. Amazed to learn how it worked at a unit -- jaw dropping. It is one system with two pieces connected with mounts.
I like to avoid force, lever, and pressure when working on garage floor with jack-stands. Clear the floor area. You must raise and set the car on chassis.
I was at ease working when shock and spring is unmounted at transverse. Very fluid, so control it with various raising tools and techniques -- just do not panic. Not for faint heart.
You want both transverse arms free, but only suspended at the delta. Protect lines.
Taking off rear-brake clipper and disk would take the weight off too.
Rehearse and enjoy, it is a fun project.
E Showell
Post by E Showell »
Ok. More than I have time for right now. May wait until I have to renew rear suspension components.
'95 855 auto (sold)
xHeart
Post by xHeart »
E Showell wrote:Ok. More than I have time for right now. May wait until I have to renew rear suspension components.
It took me more than a year to find money, collect parts and tools, know the steps, plan for failures, eliminate associated risks, save a little, and time during a long uninterrupted weekend to complete the job.
Do not proceed as an emergency repair.
Been thanked: 470 times
Post by cn90 »
Can someone post a "long-term" review re delta link ball joint, Volvo PN 3516122?
I wonder what brand is the "best bang for the bucks"...
https://www.eeuroparts.com/Cars/Volvo/1 ... ch=3516122
- Febi: $30
- PPS: $36
- Lemforder: $133
Has thanked: 292 times
Been thanked: 765 times
One year ago I installed a pair of PPS into my daily driver, they are working great but have a lot of surface rust.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
xHeart
Post by xHeart »
Difficult to answer since it was an overhaul project for me. I collected OE/OEM parts over time and/or on sale.
