1998 V70XC Turbo Water Inlet Hose
Carboncopy
Year and Model: 1994 Volvo 850 GLE
Post by Carboncopy »
Hi all,
Would it be possible to get away with using generic heater hose to replace this line? If anyone has one lying around what are the diameters of both ends? Any help is appreciated.
obayha
Year and Model: V70 1999 Base
Post by obayha »
Not sure which line you re referring to. Got a picture?
Is it expensive or something you can't get in your area?
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Carboncopy
Its this piece of hose:
Screen Shot 2015-04-13 at 1.39.11 PM.png (47.88 KiB) Viewed 1627 times
Its not expensive, I am just unable to find it locally and I desperately need to replace it.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Spend the $7, it is well worth it. It is pre-bent and resistant to oil/heat. It is not a fun place to work with a non stock hose. Both inlet and outlet should be OEM.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The hose has two different diameters at each end so it pretty much has to purpose made. On an XC, as horrible as a PITA as it is to get to it, I wouldn't use anything but OEM to replace it. CarQuest has that hose if you have one of their stores locally but it is a URO brand hose. URO hoses don't get along particularly well with hot liquids like coolant and oil.
Carboncopy
Thanks Ozark, good news is a friend is up visiting me next week and they live right by a volvo dealer, so gonna call and see if I can't get the inlet hose from that dealer and have my friend bring it up.
francisp
Year and Model: '98 S70 GLT,'04 xC90
Post by francisp »
The Part number fpr this piece is 6842190 and is available at FCP or IPD for 13 bucks or less. It is OEM volvo made in spain or hungary. I am in the middle of replacing it and as expected, struggling to find enough room to get my apparently fat hand and fingers in a tight spot.
Has thanked: 1609 times
Been thanked: 4065 times
Yeah, it's a tough one. OP was in Canada at thread birth, s/he probably had to pay double that price with import and handling fees.
Oitsujosh
Year and Model: 99 V70 XC
Post by Oitsujosh »
I did this before I found this site. Now I know it's not ideal but I was I a pinch as it was Sunday and no one had it and had to get the car home. It's two different sizes at each end but I'm having a brain fart at the moment on what exactly they were at the time but I got a brass NPT elbow used barb fittings that screwed into elbow with a couple short lengths of hose to connect it. I did most of it front the underside with the car on ramps. It was a PITA on my 98XC, but have to say it's been holding up great with no issues thus far. I did it about 4 months ago now. I'll see if a can get pics of its later on.
99 V70xc Darkwing (goneπŸ˜”)
08 xc90 Tabitha
06 V50 T5 Awd 6spd. Skeeter
66 barracuda "very long term project"
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
No one needs the sizes now, just pulled up an old thread. I usually do it from up top. I simply pull the coolant line off of the back of the turbo and the other end with the intake tube off. Takes about an hour.
