98 v70r - Transmission kaplunk
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
JRL wrote:So what, it would still drive and shift just fine but in FWD only
So... kind of like what OP's describing, then?
- S
[Sold] '97 S70 T5
chexny
Year and Model: 1998 V70r
Post by chexny »
Thanks to everyone in this forum. I think I am just looking to move on from this car.
https://www.matthewsvolvosite.com/forums ... =6&t=74103
1988 740 -- Long gone
1998 V70r -- Current daily driver
2004 S60 -- Magically turned into a Toyota Sienna :-)
famfeld
Year and Model: 04 xc70
Has thanked: 9 times
Been thanked: 6 times
Post by famfeld »
Get your backyard mechanic to swap out the tranny for $500 plus $300 for a scrap yard tranny.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I know this is pretty obvious,
but since you haven't mentioned it,
I've got to ask... How's the fluid level?
And this might be worth a fluid swap.
That's pretty simple and low budget.
chexny
Post by chexny »
Fluid seemed fine. I obv didnt drive 30 mins to test it but after 10 min drive to the mechanic first thing he did was pull the dip stick and fluid was pink. Are you suggesting draining and filling or just topping off? It happened when it should have been pretty cold still - morning start in cold weather and 1/2 mile from my house.
BEJinFbk
Post by BEJinFbk »
chexny wrote:Fluid seemed fine. I obv didnt drive 30 mins to test it but after 10 min drive to the mechanic first thing he did was pull the dip stick and fluid was pink. Are you suggesting draining and filling or just topping off? It happened when it should have been pretty cold still - morning start in cold weather and 1/2 mile from my house.
My first thought was low fluid, but like I said, that's pretty obvious.
The other possible "easy fix" may be something bigger that it should
be floating around in there and clogging something in the valve body.
A fresh transfusion of AT juice might flush it out. Just reaching, but
I hate to see any more of these cars forsaken... :(
chexny
Post by chexny »
First - Thanks to everyone here.
I kept at it and 3rd mechanic diagnosed a bad right front shaft from a broken bearing. I attached the bearing pic - may be tough to see but it is pretty nasty. This 3rd shop (transmission specialist) said he took it out and felt it was driving right but said he didnt think it was the transmission at all. Said he had his other mechanic take it out to just see if he was wrong without telling him why I brought it in and that mechanic confirmed that the transmission seemed fine. Both said it shifts fine. So they put it on the lift and front right tire was either spinning freely or not spinning at all (he was confusing me frankly) when it should not have been doing so. Front drive shaft and bearing replacement and I am off. First 3 miles of driving so far and all seems well. We will see if I was taken here or this was the issue.
markjcm
Year and Model: V70 T5M, XC90 V8 (2)
Post by markjcm »
Edit: never mind
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
I don't see how bad drive shaft bearing can cause transmission to slip.I don't see that it's felt appart too,blocking a drive shaft.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
chexny wrote:I am done with the car.... Or just sell it like I was thinking to do. ...I am pissed with myself, this car and pretty much everything at the moment. In part I have been dumping money into it for sentimental family reasons and in part b/c i dont have +10k for a new-er car forget a new car.
So, sell it while it runs?
The most I every spent on a new to me car is $3300.
85 GLH, 367 whp
00 Insight, 72 mpg
