I checked out a family members car the other day to change the rotors and brake pads. Once I took the wheel off I was harshly surprised by metal wire sticking out on the inside of both front tires due to uneven wear. I'm not sure where the problem lies here, either suspension or alignment?
If anyone had any pointers that'd be great.
-Thanks in advance
Irregular front tire wear
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
First thing I would check is the control arms. You would see this kind of wear if the ball joint (s) are worn.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
When I check the car out again I take a better look. Bad ball joints can be spotted by trying the push the raised tire from the top and bottom to see if there is any wiggle room, correct?850 LPT wrote:First thing I would check is the control arms. You would see this kind of wear if the ball joint (s) are worn.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It depends on how bad it's worn.
Pretty bad worn out control arm ball joint can have a wiggle to 9 & 3 o'clock as well,even if that positions are for examining tie rods condition.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4068 times
It's probably bad alignment due to worn out suspension. Ball joints( which means lower control arms on these cars) and both inner and outer tie rod ends are all suspect
- 11 Replies
- 2551 Views
Last post by icrashcars
- 14 Replies
- 10049 Views
Last post by chitownV
- 13 Replies
- 1287 Views
Last post by foggydogg
- 7988 Views
Last post by tigerpaw458
- 1459 Views
Last post by oragex
