3rd radiator at 240K
Has thanked: 292 times
Been thanked: 765 times
Re: 3rd radiator at 240K
mecheng wrote: ... I've always used aftermarket (Chinese ) radiators on all my vehicles because the OEMs never last any longer, (sometimes less) and the cooling capacity is equivalent. ... they are all more or less different shades of garbage IMO.
IMO this post is completely ludicrous. :mrgreen:
So here is something you've never tried your whole life, yet you insist it is lousy because ... um, why?
The great majority of devotees to the OEM (Valeo) replacement rad will insist it lasts a good long time and will have the numbers to back that up, and that it is not a piece of crap (e.g., fitment is perfect). I've heard a lot of arguments for aftermarket on the rad, some of them even reasonable, but never that the Valeo unit is a piece of crap. Where are you getting your information, if not from personal experience and not from the forums?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
songzunhuang
Year and Model: 98 V70 T5
Has thanked: 2 times
Been thanked: 30 times
Post by songzunhuang »
scot850 wrote:I would check all your engine mounts. The top hose connecter breaks in my opinion as the engine move the most at the top and the top hose as it gets older becomes stiff and has no give which loads up that top connection more than the lower one.
Specifically check the condition of the mount under the crank pulley and the top torque mount.
Neil
Good idea on the motor mounts. I'll check that out. I know I've replaced a few of the mounts in it's history, but you never know if something else has failed.It's been a while.
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
JDS60R
Been thanked: 3 times
Post by JDS60R »
While the car is running.
Please take a DC volt meter and put the ground test lead to the battery ground post and the positive test lead in the coolant .
Please let us know the DC volt reading. I am suspecting you have an issue as your corrosion is out of hand.
Retired
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I'm not picking out Valeo perse, I just think plastic end caps are a bad design, they will all fail at the cap sooner rather than later. My Valeo lasted 200,000km, (124,000 miles) not bad nor stellar in my books. I've had Chinese rads last longer. All in all the Valeo is a good radiator, but not amazing.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Been thanked: 471 times
Post by cn90 »
Noone discusses Nissens?
I thought Nissens is an excellent choice?
dosbricks
Post by dosbricks »
Is Nissens still made in Denmark? If so, I wish I had shelled out the $$ for a couple of them.
Post by cn90 »
My only experience with Nissens (Yes made in Denmark) is with my BMW and has been excellent.
Installed the Nissens radiator in my 1998 BMW 528i back in May 2006.
Ten (10) years later, absolutely fine, zero leaks.
Don't know about Volvo, but the Nissens made for BMW is good. Pricing is competitive, it is always cheaper than stock.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
JDS60R wrote:Wow - look at the corrosion on the metal part - What are you using for antifreeze??
If the corrosion got through , or on the backside of that metal ring it would fracture the plastic easily.
I too would like to know what coolant you are using in the car.
My car currently has 305,000. I have had it since 188,000. I think the rad is just starting to leak. I have a Nissens on hand, NIB, ready to install. I may do it tomorrow.
songzunhuang
cn90 wrote:My only experience with Nissens (Yes made in Denmark) is with my BMW and has been excellent.
Hey I recently changed out the radiator in a BMW 633csi I was bringing back to life with a Nissens unit! I was impressed enough with the quality of it that I ordered Nissens for my Volvo. Unfortunately, it was one of the ones that didn't work because of the lack of fittings for both the oil and the transmission. The parts store got it wrong and I needed a radiator the same weekend. I could only find the Chinese one in short order. Still, it was only $32 cheaper than the Nissens. The APDI was $148, they wanted $180 for the Nissens.
I've seen a few all aluminum racing radiators, but they tend to be more than double the cost ($400-500). I can deal with a new radiator every 100K miles for the savings I guess...
Song Huang
songzunhuang
I was just using the regular green Peak antifreeze concentrate, diluted with distilled water. Not sure why it's so gunky. The coolant that I drained out of the car was clean enough. I didn't see any gunk in there.
Song Huang
