Replacing CVVT Solenoid for Code P1332
sweet2burs
- Year and Model: 2002 s80
hi I am getting ready to change my cvvt solenoid i ordered a used one on ebay of the exact match i did pull the part number before ordering to make sure and did look at the connector end .i have a 2002 volvo s80 will i need to have this programmed or can i simply just switch it out .since i will not have to cut any wires and also can i leave the battery hooked up again since i will only be unplugging this . i am asking this because the closest volvo dealership is over 2 hours from my location
and no one in my area will touch a volvo ???? i need to know asap since my 89 gmc currently, i have had to remove my trany on that and wont have the replacement in for a bit
allenzachary
- Year and Model: 2006 XC70
Disconnecting the battery is always the safest for you and the vehicle. But... I've changed these with the battery connected and never had an issue.
allenzachary
2006 XC70, 2002 XC70
MindOfVacuity
- Year and Model: v70 1999
Does anyone know what the bolts on the solenoid should be torqued to?
- Has thanked: 1611 times
- Been thanked: 4075 times
Torque 10 Nm crosswise
Nicknice33
- Year and Model: 2000 volvo s80 t6
I'm getting code p1332 and p0013 I just bought a camshaft positioning sensor is this all I need and will it work
Probably not the problem nick. Try replacing the CVVT, clearing codes, and see what comes back
There was a good DIY on this and IM pretty sure the OP could not get the connector from Volvo - in fact he documented how to make sure you splice the right connectors into he OEM connector really well.
- 3432 Views
Last post by RichCrewe
- 1210 Views
Last post by Sommerfeldt
- 2493 Views
Last post by v-45magna
- 12 Replies
- 5290 Views
Last post by mrbrian200
- 11 Replies
- 2606 Views
Last post by denraden03
