ATP-205 works!
mecheng
Has thanked: 15 times
Been thanked: 21 times
ATP-205 works!
Post by mecheng »
Very impressed, after one short drive the atp 205 cured my valve stem seal leak! I would get a short puff of smoke upon start up, not any more.
It only took one short trip for it to work. Highly recommended, it could prevent a valve from burning and gets my highest recommendation.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
dosbricks
Post by dosbricks »
I totally agree that of all the plethora of moose pee additives out there, this stuff is actually effective for softening/restoring seals.
I put 1oz. in the power steering and the rest in the crankcase of the S70. Now, thanks to you, I'm reminded/convinced I need to get a bottle for my 855.
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Somewhere I read that atp 205 only softens rubber and according to atp ruins plastic and teflon seals. Are there any plastic or Teflon seals in an 850 or S/V 70?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Valve stem seals on our cars should be made of teflon as far as i know.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mecheng
Post by mecheng »
I thought the valve stem seals are nitrile; anyways mine were leaking so what harm could I really do. As far as I am aware, our engines don't use plastic seals and didn't think they used Teflon. I never read that about it harming seals anyway.
I have been driving it for a couple months and it is perfect. Read the reviews on Amazon, it has cured many valve stem seal leaks.
I let the car sit for a week trying to see if any valve would leak past the seal, started the car up, zero smoke.
https://www.amazon.com/ATP-AT-205-Re-Sea ... 1_1&sr=8-1
Has thanked: 292 times
Been thanked: 765 times
I don't think the valve seals are teflon, haven't heard that one before, interesting comment. The ones I bought looked like some kind of rubber-like compound, e.g. nitrile, FWIW.
I also like this stuff, have used it a couple times.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Post by sleddriver »
Mecheng,
Glad to hear it worked for you.
Just did a PS flush & fill & reboot. Added 1.5oz to the Valvoline Maxlife ATF syn. I refilled the system with. Hoping it will stop the rack from leaking. Read really good things about AT-205 + I was able to find it locally.
M1 10W-30 HM
mecheng
Post by mecheng »
sleddriver wrote:Mecheng,
If it doesn't work, it could be because you added too little.
3oz is required for PS leaks
good luck
sleddriver
Really? Where did you hear that?
I based my dosage on what I found from an ATP video: 1.5oz/quart of fluid. This was the suggested dose for an AT. Could be different for PS. If so, I'm interested in hearing your information
M1 10W-30 HM
sleddriver
Update: Just got off the phone with ATP support re: 205. He said 2-3oz/qrt. So I'll top up with a bit more.
M1 10W-30 HM
