Volvo 850 Rear Door Replacement
This topic is in the MVS Volvo Repair Database » VOLVO 850 REAR DOOR REPLACEMENT
tailor
Year and Model: 2004 XC90 2.5T AWD
Post by tailor »
VOLVO 850 REAR DOOR REPLACEMENT 1996 SEDAN TO 1994 WAGON
How to replace a door( in this case rear door, drivers side) in a 1994 850 Turbo Wagon
I was at the U-Pull yard today and good fortune was upon me as I found a 1996 850 sedan that was the same colour as mine and did not have the rust eating away at it, so I grabbed it and made off like man possessed.
There are, as always a couple of caveats, fistfuls of colourful language and the almost inevitable missing socket : (
The door is fairly heavy, it is manageable if you are a single operator, however I would recommend a two man job as the alignment is a little tricky and you do not want to damage the paint on either the door or the car.
Open door.
1)Locate the rubber covering the electrical connection and gently pull the rubber away from the body to expose the connector. There is a single pin that locks everything, depress and coax the two pieces apart.
2)Find the door strap and remove the torx bolt.
3) There are 4 bolts that hold the door in place, also two spacers/washers, one under each hinge, take note of the orientation. Break the bolts loose, with a 12mm ratchet, this is when you need help to hold or support the door, as you remove all the bolts.
4)Installation: Support the door and connect the electrical connector and push it into the pillar. Push the excess wire into the pillar and re-attach the rubber to maintain the protective covering. Ensure you get all the wiring back into the pillar so nothing will be crimped when the door closes.
5)Align the hinges onto the door,put in washers, finger tighten the bolts. Align the door starp and put in the torx bolt.
6) This is when I closed the door and checked the alignment. Look for even space all round the door and for light between the rubber along the top of the door and body. If you see light the door needs to be closer to the body edge of the rubber. If you open the front door the bolts for the rear door are exposed. I had to do a little pulling and pushing and lifting to get the door to where I though it ought to be. Check that it opens and closes with ease. Tighten the bolts to specs.. Gut un tight, in my case.
The front doors will be pretty much the same with the exception of a different electrical connector that will have to be disconnected first .
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Tailor, almost missed this! Outstanding writeup, adding to Repair Database.
What part# is "Bag of Old Clothes"? I'll need to know for when I'm at the dealer parts window.
Also -> Amazon link
tailor
Post by tailor »
mostly size 40!
Abe Gottschalk
theador
Year and Model: Volvo 855 T5 1994
Post by theador »
Did you have a beautiful assistant to help you get the door back on, or can this be done alone?
theador
Post by theador »
Ignore that, just read the first bit again... Duh.
theador
Post by theador »
Haynes manual suggests using a trolley Jack to support the door.
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
If I told my wife I needed an old bag to work on the car I may go missing
boxpin
Year and Model: Volvo 850 95
Post by boxpin »
I know this is like 6 years later but why didnt you just remove the two reverse torx screws on the hinge and lift the door off. No need to fiddle with the hinges.
theador
Post by theador »
boxpin wrote:I know this is like 6 years later but why didnt you just remove the two reverse torx screws on the hinge and lift the door off. No need to fiddle with the hinges.
Yeah that's what I did on both the front and back doors :mrgreen:
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
skloon wrote:If I told my wife I needed an old bag to work on the car I may go missing
You wife called! :evil: :mrgreen:
