1990 240 stalls while driving but restarts??
rainbowwillow63
Year and Model: 1987 Volvo 240 DL
Post by rainbowwillow63 »
Hey Bill-
Don't you know a woman only needs 3 tools to fix anything:
1. If it doesn't move and it should, use WD-40.
2. If it moves and it shouldn't, use duct tape.
3. And if that don't work use a BFH (Big Freaking Hammer)!! :lol:
Proud owner of
1993 Volvo 240 DL
1990 Volvo 240 DL-laid to rest
1987 Volvo 240 DL-sold
1989 Volvo 240 DL-sold
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Well there you go.
My first ever car tool kit, way back in 1961, consisted of a roll of insulating tape - no duct tape then - the biggest screwdriver I had ever seen, a hammer and an adjustable wrench. It was a present from an uncle when I bought my first car and "would repair anything" (his words, not mine).
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
DeRail
Year and Model: None
Post by DeRail »
LOL Bill, I gotta stick with what works :lol:
Thanks for the update, glad to hear everything's well again
1966novacoupe
Year and Model: 2001 v70 1990 740 tu
Post by 1966novacoupe »
just an fyi. recently my 1990 740 turbo began stalling randomly. no consistency. could be at a stop or driving down the freeway and the engine would just shut off. i noticed the tach would instantly drop to zero. if i didnt turn the key completely off and back on it would not restart. the car started doing it every few minutes so i havent used it in a week.checked everything. fuel pressure, rpm sensor, ignition system etc. no faults found and no codes set. yesterday i noticed if i wiggled the key in the ignition switch just a bit it would do the same thing. replaced the ignition switch [ just the electrical part] accessed by removing the gauge cluster [easy], the car hasnt even sputtered once since in almost a hundred miles. VIOLA !
1966novacoupe
well i shouldnt have opened my mouth. the car is back to doing the same thing. replaced the rpm sensor. no change. fuel pressure remains constant at 43 psi. never starts to drop before stalling. ive heard this car has a hall effect switch in the distributor but not so. took it out tonight and nothing but a rotor. never loses power to the positive side of the coil or negative side for that matter. any suggestions ? thanks for any help.
