I'm trying to decode the Data plate so I can order the proper Timing belt kit for my 98 / s70 T5.
My Vin is YV1LS5344W2450325. The Data I find shows the last 6 numbers as my Chassis number.
But when ordering parts from Rock Auto it shows 7 numbers for engine or Chassis number.
( Example ) ( To Chassis 1266128.,) ( From Chassis 1266129 ). ( Engine No. 1266127 & Before.) ( Engine No. 1266128 & After )
So what Timing belt kit is needed?
Thanks
Ken
Decode Data plate for parts order
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
look on the front (RH side) of the timing cover. if the decals are still there and legible, it will have your engine number.
CONTITECH TB331K1 probably this one, your car should have hydraulic tensioner.
Current Volvos:
- Has thanked: 316 times
- Been thanked: 531 times
Do you have the original timing belt cover on your engine? If so, check out the engine serial number on it. That will tell you.
Otherwise, take a peek behind the cover to see if you have a mechanical tensioner or a hydraulic tensioner. "Up to 1266128" would be the latter, "from 1266129" the former. That will determine which belt and tensioner you need.
- 12 Replies
- 7138 Views
Last post by Martenk
- 11 Replies
- 19454 Views
Last post by jarkmackson
- 1920 Views
Last post by RayF
- 618 Views
Last post by Georgeandkira
- 662 Views
Last post by RickHaleParker
