Turn signal stalk
I've replaced the four way flasher switch and relay but still have no turn signals or four ways the only way I get turn signals is to press the four way switch I'm thinking it may be the stalk but how do you replace it
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I know that this video is regarding and 850 (and your car is really no different) about a turn signal not returning to neutral after turning but it will give you an idea about what is going on with yours:
Here is also a write- up regarding a turn signal stalk: https://www.matthewsvolvosite.com/forums ... =1&t=47464
Personally, I would source one from a junk hard or otherwise, you are going to be paying a lot of money for a replacement stalk and it could be the tab on the steering column side that is broken. You won't know until you get into it.
- 13 Replies
- 4041 Views
Last post by Vova585
- 2146 Views
- 1532 Views
Last post by volvolugnut
- 10 Replies
- 1901 Views
Last post by TommyMac
- 436 Views
Last post by chrism
