Starting trouble post plug wire install Topic is solved
This topic is in the MVS Volvo Repair Database » Volvo 5-Cylinder Engine Firing Order
bigdog440sp
Year and Model: 1995 850 GLT
Post by bigdog440sp »
Hello Volvo Forum I am having a problem with my 850 GLT, after a much needed spark plug wire and air filter change the car refuses to start. It was running just fine before hand.
Here is what happened
1. I first installed the plug wires in the wrong order stupidly thinking my guess work was adequate
2. i tried to start the car, it turned over but no dice
3. realized my error. looked up correct order and hooked the wires up correctly
4. attempted to start the car again, still nothing
How can i fix this?
Thanks
dorvin
Year and Model: 1997 Volvo 850 T-5
Been thanked: 4 times
Post by dorvin »
If you've verified the plugs are in the correct order on the distributor, I would check the coil, make sure that connection is tight. I'm sure other members will chime in with more helpful advice than my own soon.
bigdog440sp
Thanks ill do that now and report back about what happened.
Has thanked: 1613 times
Been thanked: 4075 times
There is at least one manual, Haynes I believe, that has bad information on the spark wire order
Has thanked: 312 times
Been thanked: 818 times
bigdog440sp
UPDATE, Do not trust google it will give you the wrong order. I found the above one on Youtube and it started without issue, I sincerely appreciate the help guys.
PS, You all are much more helpful than the Integra forums I use for my project car.
dorvin
Post by dorvin »
Glad you were able to get her started again 8) Hopefully you notice a nice improvement with the new plugs.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
We should pin this one- I know it's in the repair database but ever so often, we get this because there's false info out there...the Dealer love this!! They can charge their hourly rate and do almost nothing after the owner of the car has it towed to them...end result is just $$ down the drain!
Paul-93-850
Year and Model: 1993 850 non-turbo
Post by Paul-93-850 »
Replaced plugs and wires. Yeah, I had the order reversed and corrected it. Seems like it almost started now but I smell gas. Could it be flooded?
Flooding yes, or "lawn mower syndrome." Does it sound like maybe it is cranking too easily/freely?
If just waiting a while doesn't help then the fix for LMS is 1 teaspoon of oil in each cylinder then crank it until starts.
