Hello there,
Any way to disable the interior lights that come on when the door is opened?
I dont need them and with modern flashlights i can see much better with a high powered LED light.
I dont want to permanently disable them however, so i don want to take the bulbs out for example.
On the old Hyundai i had, the only ceiling lamp had a three way switch where you could select one of:
1. On (always on, never shuts off)
2. Automatic (when the door is opened it comes on, when the door is closed it shuts off)
3. Off (never turns on unless you flip the switch manually again to 1 or 2 above).
Alternately, how hard is it to change one of the bulbs in one of the overhead interior lights?
I might be able to swap it out for a high powered white LED Luxeon or Cree Star which would easily provide MUCH better interior lighting when it is actually needed.
Thank you.
Disable Interior Lights
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- kippster41493
- Year and Model: 1994 850
Does you dome light look like this? If so the switch is in the center, the center position will turn them off completely.
- dome light.jpg (8.27 KiB) Viewed 2793 times
1994 850 2.3 Turbo
1998 V70 GLT 2.5 Turbo
- project now
1995 BMW 530i
1998 Eclipse GSR - 3.5" off the ground and headers
1995 BMW 530i
- Has thanked: 316 times
- Been thanked: 531 times
In my V70, I believe pushing the left side of the rocker switch disables the interior lights completely. Mind you, the footwell lights will always come on with the doors, regardless of whether the dome light switch is off.
- Has thanked: 311 times
- Been thanked: 817 times
All of the interior bulbs are easy to get to, especially the overhead ones. Many people have switched over interior lighting to LEDs, e.g. https://www.matthewsvolvosite.com/forums ... =1&t=35000. LED availability has really improved since that thread was started (e.g. https://www.superbrightleds.com/) so you don't need to solder any more to do it, be sure to read some of the more recent posts. There are a lot of threads like that one if you try the search function.
- MrAl
Hi,
Thanks much, i'll look into those LED lights and the switch. Didnt think this one had a switch but if it is there i'll find it
Now that you mention it, I think some models didn't have the switch. Seems stupid, but I think I've seen it before.MrAl wrote:Hi,
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
The switch is a standard feature. All trim lines have it.
The page you want:
http://new.volvocars.com/ownersdocs/199 ... 9.htm#pg51
The whole OM:
http://new.volvocars.com/ownersdocs/199 ... 70_000.htm
The page you want:
The whole OM:
- MrAl
Hi,
Oh ok thanks for that link. I guess it is in the owners manual then.
I'll check next time i go out to the car. The switches are probably there i just didnt notice them yet because they are overhead.
The switches must be there.
Yes, the switches are definitely there.
- 1424 Views
Last post by Abrown99
- 471 Views
Last post by draser
- 952 Views
Last post by msmith2508
- 544 Views
Last post by Ozark Lee
- 1784 Views
Last post by erikv11
