96 850 GLT Tire Pressure info?
dudeman
Year and Model:
Post by dudeman »
The tire pressure info is not on the driver's door jam.
I've looked around for it and can't find it.
Can someone tell me where to locate it?
What would my target tire pressure be for my 96 GLT?
Thanks!
- dudeman
96 Volvo 850 GLT
Goin' strong
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I think the sticker is on the gas door. I run mine at 35 lbs.
dudeman
Year and Model:
Post by dudeman »
I have a replaced gas cap. Nothing on it.
Do you put 35 psi on all 4 tires?
- dudeman
96 Volvo 850 GLT
Goin' strong
Maxbaby
Year and Model:
Post by Maxbaby »
I'm running 35psi on all four tires. That's based on the sticker inside the gas filler door.
1993 850 GLT
Close to 360,000 km
dudeman
Year and Model:
Post by dudeman »
Thanks all!
- dudeman
96 Volvo 850 GLT
Goin' strong
Tsquared
Year and Model: 11 C30
Post by Tsquared »
You can also check the tire manufacturers website. Some of them will list their recommendations on tire pressure by car type. I have found that different tires will ride better at different pressure. The 35 lb is good rule of thumb but the current set of Pirrelli 400s that are on my daughters car ride better at 38 lbs. The tire is rated to 40 or 45 lbs so I am still under the maximum pressure.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I also run 35PSI, but depending on your road condition, type of tires and tolerance for bumpy rides, you can go more or less....more if you like a tight ride and don't mind the bumps....less if you want a softer ride and don't mind some loss of handling. 32~40 or so seems to be fine as far as wear on most tires.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Way too much. 30-32 is fine for all Gen 1 cars unless FULLY LOADED UP
turbotim2
Year and Model:
Post by turbotim2 »
I just looked at mine and it says 36 front, 41 rear. I run mine at 35 though.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
JRL
Post by JRL »
turbotim2 wrote:I just looked at mine and it says 36 front, 41 rear. I run mine at 35 though.
You guys do NOT know how to read these.
When driving alone or with one others you use THE OPTIONAL pressure which is about 32 or so.
The "standard pressure" is for a fully loaded up vehicle, READ the labels
