850 vacuum hoses
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Covert
Year and Model: 1997 850
Post by Covert »
Thanks fellas, here is the thing on the front panel that has a rubber hose from it . I assumed it went to the inlet manifold
Covert
Post by Covert »
Here are the other two lines from the charcoal cannister
Been thanked: 4071 times
Are you in MA one hour from me in summer or the one in the UK named after ours?
Covert
Post by Covert »
No im in the UK unfortunately matey
That flag was a subtle hint..
Usually the purge valve is up there on the front but that doesn't like the one we get over here.
Covert
Post by Covert »
Well whatever it is on the front panel it goes to the inlet manifold , found an image before i started ripping into it .
And both of the black hard pipes from the charcoal canister go to the back of the throttle body , must be different to your versions over there ....
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
scot850 wrote: Hope this helps!
Neil, that's where that line goes!! Thanks for posting this!!
Retired:
2015 Volvo S60, T5, 85K
Has thanked: 2205 times
Been thanked: 1852 times
Glad it was of help Marco!
