Head gasket 2000 S70
michaelw84
Year and Model: 2000 s70
Post by michaelw84 »
just removed head to replace head gasket now i just have one question before reinstalling...is it a must that head hould be planed ,it didnt overheat head looks ok but im sure its warped somewhat car has about 180000 miles on it.....just need to verify bfore i go any further....what are my options
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
You need to check the cylinder head for straightness or paid to get it checked.
85 GLH, 367 whp
00 Insight, 72 mpg
Been thanked: 471 times
Post by cn90 »
If cyl head is straight (use a straight edge to check), then there is no need to plane it.
Year and Model: 98 V70GLT, 98 S70T5M
Post by 101 »
You can definitely check it with a metal straight edge as cn90 said above ... but if you are planning on keeping the car for a while longer I highly recommend having the head fully inspected and the valve stem seals replaced with OEM Volvo seals by a competent machine shop. It's an investment that will save you tons of grief later on.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Greetings. In my opinion, have the head checked by a good shop. What were the signs of HG failure ? I understand your questioning of planing the head. I had a head go bad due to a waterpump locking up. Threw timing belt and bent valves. Did not overheat. 142,000 mls. I had a PNP head rebuilt . I kept my original . At your mileage, you might consider new valve seals since head is already out. But , I due understand budget concerns . Just would hate for you to do all this work and have old valves seals leak . Good luck.
Has thanked: 292 times
Been thanked: 765 times
Some +1 comments ...
For sure have the head checked, probably planed too, by a good shop. Not any shop, but a good one. I tend to trust the machinist for the machine work.
I've pulled several heads now, I can't imagine pulling a head from a p80 car and not replacing with new valve stem seals, which must be Volvo brand as mentioned. Almost guaranteed they are leaking now. Unless you are just trying to get a year of basic transportation out of this car, do them now and avoid the otherwise almost inevitable burnt valve.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
michaelw84
thanks for the responses.....I did check the head with a straight edge which looked good so I decided to just put the head back in without doing all the work on valves and such....head gasket was actually good...what I found was 2 loose head bolts by cylinders 3 and 4 which were filled with water...car is back together and runs and sounds good but does not accelerate when I push down on gas peddle...it just bogs down. Now I did end up with a vacuum line that comes from the intake manifold..i swear I marked this when I took it apart but I cant figure out where it goes.....I have been looking in vicinity of throttle body but have yet to find it....when I do push down on accelerator I do hear some what of a sucking noise just haven't located and im pretty sue the vacuum line is the problem....its a white 3mm vacuum line...does anyone have an idea where it goes to from the intake...Thanks
There's a handful of vac lines, a pic will make it crystal clear if you can post one. The site can host pics directly. I don't actually know the vac line routing very well for 2000 but someone will know.
Is this car a turbo or NA?
'06 S60 R, 197k
michaelw84
ok here are pics of vacuum line it is the white one coming from the intake manifold...I believe it goes somewhere near or on throttle body cant see anything at a quick glance haven't had time to dig a lil deeper so im asking for any one with any idea where it may go
clifford06
Greetings. I popped my hood to compare to mine . No match. You must have a non turbo.
Just wondering, if you found loose head bolts, if tightening them would have made a difference ? Just a thought before I replace my leaking headgasket.
