No voltage going to hazard switch
jalbs
Year and Model: 2001 S40
Post by jalbs »
In testing why my hazards don't work I found the green-red wire has no voltage. This line is supposed to be constant voltage and only the yellow line for the switch light has voltage. I am not sure how to trace this but from my research it should be coming diretly from the fuse box (c17).
What are distribution rails under the dash? I saw on one diagram it mentioned this also had something to do with the hazards.
Any ideas?
jalbs
Post by jalbs »
Problem solved. Water corroded the C harness in the fuse box so my green-red wire wasn't providing voltage.
