This morning, at 15 degree F, car slowed down and stopped in traffic light. I could feel a sudden shake of car/engine and back to normal. CEL was blinking while waiting for traffic light. Once car started moving on green light, CEL became solid ON. Driving on highway and back road were normal/fine with CEL ON.
I pulled code from A2: 545, 552. A1 had no code (1-1-1). I replaced spark plugs in October (Volvo plugs) about 2000 miles ago. Distributor cap/rotor were replaced back in 238000 miles. Car is about 336000 miles. Would it be time to replace distributor cap/rotor along with spark plug wires ? I reset fault codes this morning.
Thanks,
Ching-Ho Cheng
1995 855 NA: CEL on when stopping in traffic light
- Has thanked: 311 times
- Been thanked: 817 times
Timing belt and water pump, there is definitely no need to replace yet. And they are not likely the problem. Serb belt 100k is a long interval.
Most likely cause of stumble coming to idle is a vacuum leak.
Wires could be due, the Bougicords are easily good to 100k but I don;t like to go more than that. Cap and rotor, time for new Bosch items.
Sure. The factory pump I always go three changes on (225k). Then every other change.
lcc014
- Year and Model: 855, 1995
- Has thanked: 2 times
- Been thanked: 11 times
Water pump was changed along with Timing Belt back at 280k miles. After I cleared code this morning. So far, driving is fine and no CEL at 30 degree F. Could it be bad gas too ? I refilled gas yesterday morning (Mobil Super) from a station which I have not visited for a long time.
I ordered distributor cap, rotor and wires this afternoon from Boston Volvo. This is the first time that I had "misfire" faulty code in this 21 years old Volvo.
Thanks,
Ching-Ho Cheng
Thanks,
Ching-Ho Cheng
- 2445 Views
Last post by jvl
- 1528 Views
Last post by kumulipo
- 1301 Views
Last post by VolvoCANBus
- 10 Replies
- 1533 Views
Last post by rguzz
- 1786 Views
Last post by Brucebo
