Newb's situation Topic is solved
bgp
Year and Model: 1997 850 T5 wagon
Post by bgp »
Hello.
First time Volvo owner,bought an 1997 850 T5 wagon for a steal (900usd)
It was running fine until yesterday when the local weather took a turn for single digits overnight.
Went to go out yesterday morning and it would turn over and crank,but not start. The previous owner put a so-so battery in it to begin with,so I bought a brand new battery. Went to start the wagon,and I get nothing,not even any cranking. The lights,radio and everything else works.
I can even hear the fan whirring in the engine bay.
So what gives? Did I somehow burn out the starter?
One thing I need to mention is that when I tried to start the car before on the bad battery,the emergency hazard lights came on of its own,then eventually they turned after a few minutes even this happens after I put in the new battery.
Thanks in advance!!!
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
Maybe ignition switch, see what others have to say. Always something to think about when there is weirdness on starting attempts. You can always try direct current to starter and see what response you get on that front.
bgp
Post by bgp »
Okay rguzz,I'll attempt that. Thanks!
From reading I'm now guesstimating that it wasn't the fan whirring,but rather the fuel pump?
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
A faulty cam positioning sensor will lead to a no start situation as well.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 2200 times
Been thanked: 1852 times
Lock and un-lock the driver's door lock using the key a couple of times and then try again.
This re-sets the immobiliser.
bgp
Post by bgp »
Okay.............Just went outside.........It cranked over and started on the first try........Thanks Neil!!!!!
Curious and curiouser.
Seems that I need to read up here on what I need to know.
beigg
Year and Model: 850 97
Post by beigg »
FP Relay. Replace it.
Your imob was as a result from the battery being cranked deads.
ugh smh 850 Turbo fridge
bgp
Post by bgp »
Thanks to those who replied and gave me possible answers to my questions...rguzz and 850 LPT!
Evidently unknowingly I did what Neil (scot850) recommended and it seems like the problem is solved...
I'll also look into the replacement of the FP relay as suggested by beigg as well.
Who would have known?
Not this newb....LOL!!!
rguzz
Post by rguzz »
I have a feeling your troubles might well return. Maybe just the "Volvo" voice within that I can almost never entirely silence. But for now, enjoy the happy starting!
The non-start issue when the hazard lights come on when the battery is re-connected seems to confuse the immobiliser system. Only way to re-set it is to re-set the immobiliser system using the lock/un-lock with the ignition key. I had the same issue with a 97 850 I was working on as a project. Car is still running 3000 miles later. Always handy to have the spare FP relay in the glove box and a torx wrench of the right size to take the fuse box cover off to access the FP relay.
