96 850R Losing Oil
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Your car has a turbo, you really should use FULL SYNTHETIC.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It's highly recommended but not necessary.Quality semi synth is also an option.rspi wrote:Your car has a turbo, you really should use FULL SYNTHETIC.
Also....5w-30 for Florida temperatures is too thin.
5w-40,5w-50,10w40 or even 10w-60 is recommended for Florida temperatures.
Since it's "R" it would be more happier 5w-50 or 10w-60 racing oil.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tryingbe
- Year and Model: None
- Been thanked: 26 times
The issue I have with term semi synthetic/synthetic blend is, you can have 99.9999% of convention oil with 0.0001% of synthetic oil in there, and legally you can call the oil "semi synthetic" or "synthetic blend". You literally have no idea what you're buying. You'll be better of buying 4 qt of conventional and 2 qt of synthetic then mix it yourself so you know what's in there.misha wrote:It's highly recommended but not necessary.Quality semi synth is also an option.rspi wrote:Your car has a turbo, you really should use FULL SYNTHETIC.
Same type of issue with Group III synthetic, Group IV synthetic, and Group V synthetic oil. They all different but they are all called synthetic.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Perhaps a better question on my part; OP, does the oil light work on your car?
- misha
As you know...when it turns on,it's too late.
What i was talking about is higher internal wear because of not enough oil in the engine.
With 3 quarts low...it was at 50% of crankcase capacity.Some internal wear occured for sure....time will show.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 312 times
- Been thanked: 818 times
Yes!rspi wrote:In Florida, you should be running 10w-40. ...
- rspi
Contact rspi..
Light usually doesn't come on until about 4 to 4-1/2 quarts low (intermittently). Ask me how I know.
tryingbe
It's a oil pressure light, not oil level light.rspi wrote:Light usually doesn't come on until about 4 to 4-1/2 quarts low (intermittently). Ask me how I know.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- rspi
Contact rspi..
Lol, I'm well aware of that. When you have about 1.5 quarts left, and you make a turn, and the pick up sucks up air, the light comes on because there is no pressure at the sensor.tryingbe wrote:It's a oil pressure light, not oil level light.rspi wrote:Light usually doesn't come on until about 4 to 4-1/2 quarts low (intermittently). Ask me how I know.
- 1701 Views
Last post by Rbaratt
- 2211 Views
Last post by Sommerfeldt
- 1599 Views
Last post by cuhfs
- 13 Replies
- 3328 Views
Last post by 93Regina
- 13 Replies
- 2252 Views
Last post by BEJinFbk
