96 850R Losing Oil
wackenhut
Year and Model: 850R 1996
96 850R Losing Oil
Post by wackenhut »
I had an oil change at the end of June and they put synthetic and said I should be good for 7,500 miles. The engine had about 203,500 at the time. Just brought it back to get checked out cause the engine was occasionally sputtering at start up, but it is hit or miss. They couldn't find anything, but said I needed an oil change as it was dark and is over 2 quarts low, but did not mention anything wrong with the engine. It was actually 3 quarts low! Should I bring it back or is this normal?
Thank you.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
3 QUARTS LOW???
Top it up to the middle of the dipstick....if damage isn't allready done and hope for the best.
I would never understand WHY is it so hard for people to check oil level at least monthly?
What oil viscosity is in the engine?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
wackenhut
Post by wackenhut »
5W30
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Was the oil light on?
wackenhut
Post by wackenhut »
No lights were on
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
My wife was driving her NA 4 quarts low before i heard the rods knock. The light never came on though. Btw., the NA survived, these fortunately have tough bottom ends as someone told me back then.
Also, switching to synth increases oil consumption on alot of high mileage vehicles
Check regularily!
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
wackenhut
Post by wackenhut »
Thank you!!
wackenhut
Post by wackenhut »
Is it true that once you change to synthetic, you can't go back to a synthetic blend?
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
wackenhut wrote:Is it true that once you change to synthetic, you can't go back to a synthetic blend?
Use whatever type of oil (synthetic/conventional/blend) you want, but keep the oil level checked and full.
You will have no one but yourself to blame if you run it out of oil and seize the engine.
Your engine probably needs a PCV service and a have its valve stem seals changed.
https://www.matthewsvolvosite.com/forums ... hp?t=57864
https://www.matthewsvolvosite.com/forums ... hp?t=76949
85 GLH, 367 whp
00 Insight, 72 mpg
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
In Florida, you should be running 10w-40.
