Hi Everyone,
Need some advice on diagnosis of engine hesitation on a 2002 V70 XC (currently ~150,000 miles). I bought it at 134,000 miles and it was fine till about 140,000 miles when I started experiencing some hesitation at idle. It has gotten worse to the point that now sometimes the engine dies when I press the accelerator pedal when the light turns green. The hesitation problem is intermittent and sometimes I can drive it fine with no issues. I have replaced the ETM, spark plugs and checked MAF. So far I haven't found anything obvious. There was a problem where I was blowing a 10 Amp fuse in position 5 of the fuse panel under the hood (position 5 is labelled PVC/valves/fuel leakage pump). That may or may not be related to the hesitation issue. I just put new tires on the car and was hoping to get another couple winters out of car as I have two kids in diapers (not much extra cash for car loan). Any advice would be much appreciated.
Regards,
Scot
engine hesitation at idle on 2002 V70 XC
- Has thanked: 1504 times
- Been thanked: 3817 times
Check to see if any codes are pending or set.
Possibilities are vacuum leaks, clogged PCV, bad coils ( age?)
We don't host them here by agreement with Volvo but, believe it or not, volvowiringdiagrams.com was active a few years back...
