P0101 and P2188 codes
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
CEL comes on periodically with these two codes. Then it goes away, then comes back. Car is running OK, steady idle, good power.
Suggestions? I already cleaned the MAF, but the codes eventually come back.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
What car is it?
Cleaning MAF does nothing, you need a new one. Car runs fine, because ECU sees it can't rely on MAF sensor reading and switches to preprogrammed values. It injects more gas to keep cat.converter cool.
hu5ker555
Post by hu5ker555 »
Sorry...2005 S60 2.5T
Do I need a special tool to remove the security torx screws?
Any suggestions on where to get a new MAF?
My next step was to smoke test it with a cigar.
vtl
Post by vtl »
https://www.fcpeuro.com/products/volvo- ... 0280218088
or, if you like blue boxes
https://www.fcpeuro.com/products/volvo- ... 0-31342414
You can also start with a used MAF.
A hole in intake would cause an uneven idling and a LEAN fuel mixture.
hu5ker555
Post by hu5ker555 »
Thanks for your responses. So, a P2188 code would not be caused by a vacuum leak?
I saw some MAF's available on ebay for about $20. Maybe I'll start there.
Could it be a dirty throttle body?
vtl
Post by vtl »
P2188 is a too rich air-fuel mixture, not lean. Vacuum leak == lean mixture.
