Hi All,
Ok so I recently replaced a damaged condensor on my car...Replaced all the O rings and so on. Went to get it gassed up..Ac guy said he got about 700grams of gas in it. He said he could not find the tx valve and told me its prob blocked. After research I find out 850s dont have a tx valve but an orifice or expansion valve. So I pulled the radiator resivour and ecu box. To my amazement the orifice valve is nowhere to be seen. Just the normal pipes. Any ideas..
volvo 850 ac orifice tube
- Has thanked: 1611 times
- Been thanked: 4071 times
It's in the pipe, right at the big joint in front of the timing cover on LHD, I think it's the same on RHD
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
It's up near the firewall in the liquid line. I don't recall any connectors in my line. On a properly running system, you can see where it is due to sudden condensation forming, at least in a humid environment. Otherwise, you can feel for the line suddently getting cold.
Not sure if Volvo ever used TXV's on 850/s/v/c/70's....my old SAAB did. Much better way to meter refrigerant IMO.
M1 10W-30 HM
M1 10W-30 HM
- Has thanked: 311 times
- Been thanked: 817 times
You have to evacuate the system of refrigerant, then just open the pipe, pull it out, put in the new one. Pay attention to which end goes where.
- 354 Views
- 882 Views
Last post by rocketman4321
- 1598 Views
- 1349 Views
Last post by erikv11
- 5046 Views
Last post by JimBee
